What do I need to connect a Samsung Note 4 to Toshiba TDP-T45 projector.
eppt
I want to display an app on my Note 4. The Toshiba TDP-T45 is the projector I have. Since it does not have an HDMI port, I'd like to know which adaptor or cable I need to display the app.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Since it only supports VGA, S-Video and RGB, you're going to have to cobble together an MHL to "one of those" cable or an HDMI to "one of those" cable. http://www.amazon.com/Cable-Matters...ag=hawk-future-20&ascsubtag=UUacUvbUpU4952769 may work. You'll need an MHL cable or a Chromecast to convert the Note 4 to HDMI, then the adapter will give you VGA to the projector (and you'll need a VGA to VGA cable to connect it).
fallingOutOfLoveWfithTech
