1. AC Question's Avatar
    I bought my note 3 about a month ago and the battery was decent but now it only lasts around 3 hours and takes 8 hours to charge up , while being turned off. Ive replaced the battery and even done a factory reset but its still remained.Please help
    01-23-2016 11:50 AM
  2. Epic Gamer1's Avatar
    I have the same problem. My battery life also decreases on 1% by 3/4 minutes
    Does anybody have a solution for this?
    Thanks!
    01-23-2016 12:09 PM
  3. RogMoore's Avatar
    Change the battery and even better get a device with long lasting battery.
    01-23-2016 12:34 PM
  4. onnad's Avatar
    I wonder if you have a bad charger?
    01-23-2016 01:57 PM
  5. Rukbat's Avatar
    Bad charger, bad cable or bad charging circuit in the phone. Mine charges from 40% (which is the lowest you should discharge a lithium battery) to full (100% + 30 minutes) in under 2 hours. And the battery is over 2 years old.
    (If you drain every last drop out of the battery every time, you can kill it it in a few months.)
    01-24-2016 12:36 PM
  1. Lost drag to focus ability on Pure camera
    By manhattan123 in forum Moto X
    Last Post: 01-25-2016, 10:47 PM
  2. Why can't I see which application is downloading files?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 01-23-2016, 04:17 PM
  3. Replies: 1
    Last Post: 01-23-2016, 12:31 PM
  4. How to I enable my data service for the current sim?
    Last Post: 01-23-2016, 12:02 PM
  5. How to reset hangouts to always ask which phone app to use?
    Last Post: 01-23-2016, 11:55 AM
