1. roshart's Avatar
    I have had my Samsung Galaxy S6 for three weeks now and have only just discovered that the battery should have been "conditioned" from the outset. Is it worth going through the process now, having just done the initial charge plus 30mins at the start. I haven't let it run down three times - has the level already been set now? I am amazed that no-one tells you this when you buy a relatively expensive piece of equipment for which you cannot replace the battery yourself!! Thanks in anticipation.
    01-24-2016 02:21 PM
  2. dpham00's Avatar
    Honestly it doesn't really matter much. I would just use it.
    01-24-2016 02:43 PM
  3. Rukbat's Avatar
    Unless the battery was sitting on the shelf for months before Samsung got it, it doesn't need conditioning (although I still condition all new batteries - it doesn't hurt).
    There's no "set level" if you don't condition it, it will just take longer to give you full performance if you charge it fully + 30, then recharge it before it hits 40% after that. Maybe 6-10 charges before you'll get the full amount of time from full to 40%. After than it makes no difference. (If the battery is a couple of months old or less when you get the phone, it makes no difference at all.)
    01-24-2016 05:11 PM
  1. Replies: 4
    Last Post: 04-05-2016, 02:28 PM
  2. My Samsung S6 has been freezed.
    Last Post: 01-24-2016, 02:57 PM
  3. Dark background on S6
    Last Post: 01-24-2016, 02:53 PM
