1. AC Question's Avatar
    I own a Samsung Galaxy S3 Mini, granted Iv'e had it quite a while now, nearly two years but when it's plugged in, even through the mains, it still discharges, Iv'e tried many different cords and plugs and all to the same effect, I then proceeded to swap out the charging port which was what I thought was causing the problem, but despite that it still discharged while plugged in , I even bought a fresh battery and that didn't help either. I'm now very stuck for ideas and It's been bothering me why it still discharges.
    04-08-2016 10:31 AM
  2. srkmagnus's Avatar
    Is there anything running in the background? Are you using the device while its charging? Those are things that would cause a discharge while charging. If you are not sure if any things running consider a reboot, or a reset and see if that helps. Backup data beforehand.
    04-08-2016 10:49 AM
  3. Sam Nugent's Avatar
    Nope, I wiped the phone completely and turned off Wifi, Bluetooth, GPS and the lot, I even have it in Power saving mode and with the brightness down all the way, it still decharges under these conditions
    04-08-2016 11:15 AM
  1. Galaxy S7 - Excessive Battery Drain
    By Andy205 in forum Samsung Galaxy S7
    Last Post: 10-13-2016, 09:44 AM
  2. Bought Nexus 5X and didn't get reduced price?
    By aschhetri in forum Nexus 5X
    Last Post: 04-08-2016, 03:12 PM
  3. Replies: 1
    Last Post: 04-08-2016, 12:40 PM
  4. where do I find the folder for all notifications received
    Last Post: 04-08-2016, 12:36 PM
  5. Orico 10,000mAh external battery
    By RHChan84 in forum Google Nexus 6
    Last Post: 04-08-2016, 11:51 AM
