Android OS battery drain
Mar 23, 2015
11
I'm using Sony Xperia M2 Dual (D2302) for about 2 years. Since the first time I'm using it, the battery seems fine, but until now, the battery is kind of not doing what it should. And then I checked what drained my battery, and found out that Android OS is the most program that is using my battery.
I tried disabling some bloatware and auto-sync (I'm not even using it from a long time ago) but my battery still draining so fast.
Is there any solution for this?
Thanks.
These are screenshot from battery usage. I'm not even using my phone since 5.30 till now.
FalcoTinunculis
