I use my phone (Samsung Galaxy S7 Edge) as my alarm clock at night, and I put it on the wireless charger to charge, and because it holds the phone at a good viewing angle.
I''ve noticed that after the phone charges to 100 (around 3:00am), it stops charging, and even if the battery level drops it doesn''t start charging again unless the phone is removed from the charger and put back again.
When the phone is plugged into the wired charger, it stops charging when the phone is completely charged, but then it will start charging again if the battery level drops.
This means that if I charge overnight using the wireless charger, then from 3:00am (when the phone stops charging) until 7:00am (when I get up), the phone has been discharging, and is usually down to 80% or so battery level at the beginning of my day.
Is anyone else having similar issues? Does this happen with other wireless chargers? Is this problem specific to the S7 or to the Samsung Fast Wireless charger?
Is there a way to make charging on the wireless charger behave the same as charging with the wired charger? This seems like a huge design flaw, and makes the wireless charger almost useless for unattended charging.
11-21-2016 09:50 AM
