1. Obraggs90's Avatar
    Is anyone having or fixed a problem with micro SD cards constantly unmounting in their 5X?
    03-15-2016 02:14 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's often a problem with the card or with the reader. Does this happen with multiple cards? If not, then it's probably a problem with the card.
    03-15-2016 04:16 PM
  3. Shreya Bhatia's Avatar
    May be the problem with SD Card as i am not facing any problem with SD card,it is working fine.
    Try checking it with some other SD card.
    Remove it once and then insert again and restart the device.
    03-17-2016 02:23 AM
  4. Sean Fanelli's Avatar
    Maybe it's loose? Try a but of tape possible
    03-18-2016 06:14 AM
  5. dpham00's Avatar
    I would definitely try another card
    B. Diddy likes this.
    03-18-2016 09:10 AM
  1. Replies: 8
    Last Post: 08-20-2016, 06:00 PM
  2. Replies: 2
    Last Post: 03-16-2016, 01:25 PM
  3. MP3 Files Won't Transfer to SD Card
    By stuck limo in forum Samsung Galaxy S7
    Last Post: 03-16-2016, 12:01 PM
  4. S7 EDGE Problem
    By Storm Falcon in forum Samsung Galaxy S7
    Last Post: 03-15-2016, 05:20 AM
  5. Replies: 2
    Last Post: 03-15-2016, 03:39 AM
