1. Poootaatoooo's Avatar
    so i had a bootloader unlocked, rooted honor 5x running cyanogenmod, and it got waterdamaged, i was away from home at that moment, so there was about half an hour of a delay before i was able to put it in rice (i turned it off almost immediately after getting water damaged) unfortunately, the smallest torx screwdriver i have is a t6, so i couldnt take off the back to let it dry more, after 24 hours, i tried it, and everything was fine, and the camera wasn't foggy or anything, i was planning to do a full reset anyway, so i went into twrp, wiped everything except microsd, and tried to install cm 13, but it gave me an error about timezone thing, and apparently its fixed by installing the stock marshmallow rom first, then cyanogenmod, so i got the stock recovery img, put it on my sd, flashed it with twrp, and installed the latest UPDATE.APP and now im on stock marshmallow, so then I started to try to get twrp back on it, and it wasn't detected by my pc, hisuite drivers, pdanet drivers, nothing works. charging still works fine though, i tried 3 dif cables (all worked for data in the past anyway). If I buy a replacement micro USB port, will it most likely fix this? Or is there another culprit for this problem?
    TLDR;
    My honor 5x was water damaged, it's now fully working, but I can't use any cable for data, just charging, so I'm unable to use adb or fastboot, will a replacement micro USB port fix it, or is there another culprit?
    08-18-2016 11:48 AM
  2. Aquila's Avatar
    You re-enabled USB debugging and selected transfer files from the notification?
    08-18-2016 12:31 PM
  3. Poootaatoooo's Avatar
    usb debugging is enabled, i dont have the notification, its as if its plugged into the wall
    08-18-2016 01:38 PM
  4. lumivalo's Avatar
    Maybe you could transfer everything you need with Bluetooth, and ADB can be set up over Wi-Fi
    08-20-2016 01:43 PM
  5. Poootaatoooo's Avatar
    Honestly I couldn't care less about adb, I transfer files with airdroid, I need fastboot to install twrp again though.also, sometimes, my phone stops charging for a second or two, I already ordered a replacement micro USB board and all the tools I need, I'll update in about a week when they get here if it works
    08-21-2016 03:40 PM
  6. Poootaatoooo's Avatar
    In the meantime, is there any way to disable the charging sound when a charger is plugged in? Since the port is messed up, every few minutes it does the sound a few times, and it gets really annoying
    08-21-2016 03:42 PM
  7. dpham00's Avatar
    Did you check in the phone's sound settings?
    08-26-2016 03:45 PM
  8. Poootaatoooo's Avatar
    This definitely took longer than I would've liked, the tools and replacement charging board came within a week, but the torx t3 that i ordered was too big, so i had to order a t2 (couldn't find anything smaller than t3 locally), too small, so i decided to stab one of my good ginsu knives into the screw so it stuck, and twisted, and it came out in like 2 seconds. I'm not sure if I should feel stupid for not thinking of that, or if I should feel stupid for trying that, but its working now and im installing twrp, so I'm good,
    TL;DR
    F*ck screwdrivers, just grab a knife
    09-11-2016 12:08 AM
  9. dpham00's Avatar
    Did it damage the screw head when you used the knife?
    09-11-2016 08:59 PM
  10. PalakMi's Avatar
    When you plug USB cable, it's probably on charging, and not on data transfer
    09-13-2016 06:26 AM
  1. Replies: 1
    Last Post: 08-25-2016, 05:04 AM
  2. So what do you folks think about iris scanners on phones? Safe or not?
    By J Dubbs in forum General News & Discussion
    Last Post: 08-19-2016, 04:19 PM
  3. I got the 5x and the yellow screen to go with it!
    By zoenphlux in forum Nexus 5X
    Last Post: 08-19-2016, 03:25 PM
  4. Receiving text not bringing phone out of standby
    Last Post: 08-18-2016, 10:14 AM
  5. Why do my apps not have notification numbers?
    Last Post: 08-18-2016, 08:32 AM
