Call log display help
manolaren
3
Hi. The Call Log, if the contact is on my contact list, displays the Contact Name and below the Country/City instead of the Phone Number that was used to call me or the one i called. If the contact is not in my Contact List, it displays the Contact Number and below the Country/City.
Is there any way to change the setting in the first situation to display the Contact Name and below the Phone Number used? I prefer a solution without the use of a third party app. Phone is on android 7 / Emui 5.0.1 and the build is BLN-L21C432B365.
Thank you.
Just received an answer from Huawei. They said it works as intended and sadly there is no option to change it. At least i hope they will add an option to choose to display phone number or location, in their next Emui upgrade which i hope will come until the end of the year alongside Android 8.0
I also hope for some Huawei employ watching this :)
tuovst
