1. dby2011's Avatar
    FYI- received my USA Honor 7x yesterday. I'll try to have a brief review of it soon here. I did come across an unusual issue with the phone concerning the sound quality when using Google Play Music in Android Auto. The sound was horrible- very flat and no bass. When I switched to bluetooth it sounded fine. I also switched cables and it made no difference. After playing with multiple settings I figured out it was the Huawei Histen sound effects setting for the headset that caused this. You need to plug in a pair of headphones, make sure the setting is turned off, unplug the headphones then start Android Auto. Very strange issue but this seems to have solved everything. I thought I should post this in case others have this issue. I assume once US Amazon gets this in stock this forum is going to take off and someone will have this issue.
    01-19-2018 12:45 PM
  1. Can someone help me identify this game?
    By rogerchew in forum General News & Discussion
    Last Post: 01-29-2018, 01:20 AM
  2. Android Phones With Wide Angle Camera like LG?
    By Lord Rinzler in forum General News & Discussion
    Last Post: 01-20-2018, 01:02 PM
  3. halo effect problem
    Last Post: 01-19-2018, 12:00 PM
  4. Zooming in and out on the Note 8 using S Note
    By TordSkoog in forum Ask a Question
    Last Post: 01-19-2018, 11:59 AM
  5. halo effect problem
    Last Post: 01-19-2018, 11:46 AM
