missed call not showing up in notification and settings shortcut
culda1984
8
I recently got an Honor 8, and my missed calls are not showing up in notifications. I don't know about any missed calls until I open the dialer app. I also don't see the dialer app in the notification setting. Can someone help me with this problem?
I also can't find the edit option for the settings shortcut after the initial setup. Where can I change the shortcuts?
Thank you.
Dconn1975
Banned
Aug 19, 2016
2,529
Thank you.
I'd do a hard reset to your phone and see if that clears it up. I can't think of any speficic way you can resolve that issue single handedly. Unless another chimes in and gives you an idea I'd do a hard reset and recovery reboot to your honor and that should but things back in order for you. Just back up your data. Hope that helps.
Sleezzyy21
