1. culda1984's Avatar
    I recently got an Honor 8, and my missed calls are not showing up in notifications. I don't know about any missed calls until I open the dialer app. I also don't see the dialer app in the notification setting. Can someone help me with this problem?
    I also can't find the edit option for the settings shortcut after the initial setup. Where can I change the shortcuts?
    Thank you.
    06-03-2017 10:43 AM
  2. Dconn1975's Avatar
    Thank you.
    I'd do a hard reset to your phone and see if that clears it up. I can't think of any speficic way you can resolve that issue single handedly. Unless another chimes in and gives you an idea I'd do a hard reset and recovery reboot to your honor and that should but things back in order for you. Just back up your data. Hope that helps.
    06-03-2017 11:17 AM
  1. OnePlus 3T - Notification Drop Down Menu - Lock Buttons
    By AC Question in forum OnePlus 3 & 3T
    Last Post: 06-03-2017, 02:06 PM
  2. want to access google apps in mu device
    Last Post: 06-03-2017, 01:07 PM
  3. Unknown icon on notification bar
    By Chandu98 in forum Ask a Question
    Last Post: 06-03-2017, 12:12 PM
  4. How do I set a custom ringtone for a text message
    Last Post: 06-03-2017, 12:10 PM
  5. Replies: 1
    Last Post: 06-03-2017, 10:56 AM
