04-24-2018 01:59 PM
62 123
tools
  1. Morty2264's Avatar
    Yes!!! This happens to me so often. Like I'll leave my phone on a table and after a while when I pick it up it lags for like 3 seconds before becoming speedy and responsive again.
    It lags like crazy when apps are updating in the background also for some reason.
    I'm so sorry that you are experiencing this! I turned my phone off for Church this morning and since turning it back on, I haven't experienced any lag. Perhaps I need to shut off my phone more often than once weekly... But still. The lag can happen after a couple of minutes of inactivity or a handful of hours. Weird that this is happening. But, my phone is 15 months old, and has been running great overall! So I guess some lag is to be expected at this "age." How long have you had your Honor 8?
    03-11-2018 05:57 PM
  2. Ayush Rao's Avatar
    I've had mine for exactly a year.
    Morty2264 likes this.
    03-11-2018 09:56 PM
  3. Morty2264's Avatar
    They say that after the year mark, phones can start showing their age. I'm sorry this is happening to you right at the year mark, though!
    03-12-2018 07:02 AM
  4. Ayush Rao's Avatar
    Well today afternoon I recieved the January patch along with a bunch of features and ever since the issue has gone. I guess it wiped out old cache and cleaned up the storage since I got almost 1.5 GB space back.
    03-12-2018 07:06 AM
  5. Morty2264's Avatar
    That's awesome! I'm so happy for you!
    Ayush Rao likes this.
    03-12-2018 07:11 AM
  6. Ayush Rao's Avatar
    Thanks! Did you get the January update?
    Lol I was getting worry after seeing it lag as I was planning on using it for another year especially since it is recieving Oreo now!
    03-12-2018 07:26 AM
  7. Morty2264's Avatar
    Yes I did! The lag hasn't shown up for the past little while so hopefully everything is good on my end now, too! We're getting Oreo?! Cool beans!
    03-12-2018 07:29 AM
  8. Ayush Rao's Avatar
    Well today my phone just randomly shut off at 19%. Surprisingly on rebooting it didn't take me back to 19% (It usually boots back up to the same percentage if it was an issue with the battery not being able to supply enough voltage) but just complained of low battery and shut off. With just a minute on charge my phone now claims it is at 4% and is consistently stuck there. Does anybody know what's happening to my device since I doubt it is a battery issue? I'll try completely killing it and then charging straight to 100% to make sure it isn't an issue with calibration. Does anybody have any ideas I can try?
    04-24-2018 09:29 AM
  9. orangecroc's Avatar
    That sounds sever, I would have it returned under warranty.
    04-24-2018 10:22 AM
  10. Ayush Rao's Avatar
    Unfortunately my phone is past a year old now.
    04-24-2018 11:36 AM
  11. orangecroc's Avatar
    Have you contacted honor support through the hihonor app?
    04-24-2018 01:56 PM
  12. Ayush Rao's Avatar
    I thought I'll experiment a bit though. Killing the phone and then charging seems to have helped. I had a small issue with the battery percentage being stuck but that got solved by rebooting and wiping cache in stock recovery. Will report if I face the issue again.
    04-24-2018 01:59 PM
62 123
  1. My phone cannot get to normal menu after reset
    Last Post: 01-29-2018, 11:35 PM
  2. How do i get this onsréen keyboard off of my notepad?
    Last Post: 01-29-2018, 02:22 PM
  3. How can I set Date and Time if there is no option of date and time in Settings?
    Last Post: 01-29-2018, 05:55 AM
  4. Why pause video in youtube in after playing with 10 seconds
    Last Post: 01-29-2018, 05:18 AM
  5. What is the 2 buttons at the back of my tab?
    Last Post: 01-28-2018, 11:17 PM
