It's out of warranty, unfortunately...
Sent from my FRD-L04 using Tapatalk
Your phone shutting off because it is too cold outside; or are you experiencing that battery issue?
Battery issue with me too. The cold is a separate issue that I figured would happen.
That's probably down to temperature. Was it cold?Okay, so I was walking home from work and using my GPS. My battery was at about 60%. And then it just turned off! It said the battery was at 1% (it wasn't). It worked for maybe five minutes afterward and then shut down. Now it seems to be working okay... but I'm not thrilled.
Has anyone else's phone done that - turn off and then will work periodically?
That's significantly below the operating temperature so I would not be worried in this instanceYes, I was just about to edit my post! It was -13 with the windchill; so it was probably the weather. But in the moment, I of course panicked.
The battery issue.
Does this happen everyday or only once in a while?Battery issue with me too. The cold is a separate issue that I figured would happen.
Turns out draining he battery to like 15% etc. every day is harmful for the battery. Not sure how but that's what I gathered from online articles.I've had my Honor 8 for almost 14 months now and I've yet to experience a battery issue like that. I've noticed that my battery life - though still very good - is obviously not as great as it was a year or even nine months ago; but I've never had the phone shut down like that. Most nights I plug it in with about 18-25% left.
But yes, that is definitely a concerning issue to have. I'm curious to see if other users here have had the problem, as well.
80 percent of the timeDoes this happen everyday or only once in a while?
Yea but that's unfortunately how our current battery technology works. It isn't a Honor specific problem. Every manufacturer faces this. Apple throttled their phones just to avoid this.For me that equals using my phone is harmful. I guess we're supposed to plug in before it reaches 40% or something. Crazy
Well it's best to keep the depth of discharge small to keep the battery in the best healthTurns out draining he battery to like 15% etc. every day is harmful for the battery. Not sure how but that's what I gathered from online articles.
Apple also will replace the battery for just $29 at least for this year, which I think is very reasonableYea but that's unfortunately how our current battery technology works. It isn't a Honor specific problem. Every manufacturer faces this. Apple throttled their phones just to avoid this.
Yup and their stores are literally everywhere so battery replacement is really easily.Apple also will replace the battery for just $29 at least for this year, which I think is very reasonable
