Save big + get 3 months free! Sign up for ExpressVPN today
09-28-2017 03:24 PM
57 123
tools
  1. dpham00's Avatar
    Yeah, the front FPS is the main reason I haven't fully replaced my 6P with the OP3T I've had for 2 months.
    I guess i don't have that problem. I put the phone in my pocket head first and facing inside to my leg. When i pull the phone out, my thumb is on the front fps to unlock it
    06-18-2017 09:08 AM
  2. Byrese's Avatar
    After owning an Honor 8 definitely the back.
    Morty2264 likes this.
    06-18-2017 03:16 PM
  3. dpham00's Avatar
    Have you owned any phones with a front fps?
    06-18-2017 05:07 PM
  4. Byrese's Avatar
    Yep...Note 5
    06-18-2017 06:24 PM
  5. dpham00's Avatar
    Yep...Note 5
    Ah that's cool then. Just wanted to make sure that you tried one with a front fps so you knew how to compare the two.
    06-18-2017 07:37 PM
  6. codeda's Avatar
    I like both for different reasons. Have used lots of phones with them in each place. The only I have really not liked so far is the galaxy s8. Disabled it after a bit and went with an old school pin and smart lock. Other than that I'm happy with front or back as long as it is fast and reliable
    06-27-2017 09:06 AM
  7. dpham00's Avatar
    Well the s8 was presumably a last minute effort because they couldn't get the on screen fps to work. Hopefully it should be corrected in a future model
    06-27-2017 09:13 AM
  8. anon(9918034)'s Avatar
    I don't really have a preference as long as they work. on my s8+ I only use the iris scanner. it works so well and it's so nice to just pick up my phone and look at it. I even wear glasses and don't have issues with it working.
    06-29-2017 01:00 PM
  9. dpham00's Avatar
    Good point about the iris scanner. The iris scanner has to be used with the phone directly facing the eye right?
    06-29-2017 01:41 PM
  10. anon(9918034)'s Avatar
    Yup, it doesn't need to be jammed in your face. It works at normal viewing distance.
    dpham00 likes this.
    06-30-2017 10:38 PM
  11. Aljean Thein's Avatar
    Fingerprint on the back is a must for me. Sticking with my Honor 8 till the 8 Pro is lil cheaper
    08-09-2017 03:16 PM
  12. Snapphane's Avatar
    As a P10 Plus owner, I don't mind the front scanner even if the wife's Honor 8's back scanner DO feel better.
    What I'm missing from Honor 8 is all the shortcuts like browsing photos and pulling down the notification shade. Add in some of those features and they could probably even put it on the side, Sony style .
    09-14-2017 12:13 AM
  13. dpham00's Avatar
    Those are on the honor 8
    09-14-2017 10:47 AM
  14. Snapphane's Avatar
    Yes, they are on the Honor 8 and if they would also be on the other phones, placement of the scanner wouldn't matter as much
    09-14-2017 12:55 PM
  15. dpham00's Avatar
    Yes, they are on the Honor 8 and if they would also be on the other phones, placement of the scanner wouldn't matter as much 😊
    Oh so those aren't available on the p10+?
    09-14-2017 01:17 PM
  16. Snapphane's Avatar
    Nope, we only have the fancy "3 in 1" button for navigation.
    Attached Thumbnails Fingerprint Scanner: Front or Rear?-screenshot_20170914-202942.jpg
    09-14-2017 01:32 PM
  17. dpham00's Avatar
    Oh wow. That sucks... Hopefully they will add it... That's a nice feature and the fps swipe to open and close notification panel also works on my note 8
    09-14-2017 03:14 PM
  18. SactoKingsFan's Avatar
    Used to strongly prefer back FPS but after using for a while I don't mind it on the front with gestures enabled.
    09-14-2017 06:05 PM
  19. Aljean Thein's Avatar
    I just saw the P10/Plus for the first time today. and played around with it and saw the FPS on the front. it's nothing too bad. you will get used to it but I still love the back fps
    09-14-2017 08:30 PM
  20. Morty2264's Avatar
    Thanks for this screenshot! Love tweaking around with my settings!
    09-22-2017 01:23 PM
  21. fatproduce's Avatar
    I have a smartwatches always paired to my phone, so having a fps on the back while the phone is lying on a table isn't that big of a deal to me. I prefer to have it on the back actually. But I'm coming from being a long time LG user.
    09-26-2017 08:47 AM
  22. Aljean Thein's Avatar
    The fps on the back is more aesthetic than the front
    09-26-2017 06:59 PM
  23. fatproduce's Avatar
    Agreed! Plus I love that I don't have to press a button/fps for it to read and wake the device!
    09-27-2017 08:51 AM
  24. Aljean Thein's Avatar
    I do hate how they would make the back fingerprint scanner as the home button to wake up/put to sleep the device too. I like the button on the side for that
    09-27-2017 03:06 PM
  25. fatproduce's Avatar
    I did get used to it as time went on on my V10. It just wasn't as fast an action as I would like. I still miss trouble tap to wake and sleep.
    09-27-2017 03:39 PM
57 123
  1. Pixel XL or LG g6?
    By vhl71 in forum Google Pixel & Pixel XL
    Last Post: 06-16-2017, 12:09 PM
  2. No updates - is this normal or an issue with my phone
    By Wbutchart1 in forum Samsung Galaxy S8 & S8+
    Last Post: 06-15-2017, 06:00 PM
  3. Dripplers article about the fingerprint scanner
    By eric002 in forum Samsung Galaxy S8 & S8+
    Last Post: 06-15-2017, 04:48 PM
  4. Google Play gift cards, Fun or Fake
    By Cold Shadow in forum Ask a Question
    Last Post: 06-14-2017, 02:01 PM
  5. Replies: 1
    Last Post: 06-13-2017, 04:43 PM
