1. skilletrx's Avatar
    Hi all, first smartphone; one think I liked doing a lot was enabling bluetooth on the fly when I needed to. IS there anyway to turn on my bluetooth on the phone WHILE on the phone with someone?
    ALSO, is there a way to perform speed dial? I used to open up my phone and press and hold a number to call someone.
    Thanks in advance.
    11-28-2009 10:03 AM
  2. uujim's Avatar
    Thanks in advance.
    Yes, you can access other programs while on the phone, including going into Settings and turning on Bluetooth. I just verified this on my Eris.
    And yes, you can set up speed dials. While at the Phone screen, press the Menu button. You'll see a Speed Dial choice.
    11-28-2009 12:53 PM
