1. oasis9389's Avatar
    I tried taking off my battery cover while the phone was charging and didn't realize. Now my cover has a slight bend to it and it will drive me crazy.
    Will the sprint store give me a replacement cover or is there anywhere I can buy a new one ?
    Thanks for the help
    07-06-2011 10:17 PM
  2. WatermelonSlim's Avatar
    Hopefully they release the HTC battery cover that has a kickstand soon. At least I'm hoping it's a battery cover and not a full case.
    07-06-2011 10:34 PM
  3. footysr's Avatar
    That clip by the micro usb port is TIGHT! Hope you get it worked out.
    07-06-2011 10:42 PM
  4. thatwilsonguy's Avatar
    I don't remember where but i found one via Google. It was $32 or $38 so I passed. I also found a whole chassis for $90. I want to buy an extra so i can try to graft a kickstand into it.
    07-06-2011 10:42 PM
  5. oasis9389's Avatar
    Well I had the usb charger in not realizing that I had to take it out to pull the cover off. The 4g you could do it that way
    07-06-2011 10:48 PM
  6. creektrack's Avatar
    EBay son.....they even have different colored full bodies...
    07-06-2011 11:01 PM
  7. irock1985's Avatar
    maybe because im sleepy but I dont see any battery doors on Ebay atm... links anyone???
    07-07-2011 01:29 AM
  8. oasis9389's Avatar
    same here.. i see tons of cases for the evo3d on ebay, however i am looking for the OEM battery cover just to replace the one i have. Maybe i will go to a corporate spring store today.
    07-07-2011 07:53 AM
  9. iduarte21's Avatar
    This is the only place I've been able to find it so far......
    .Battery Cover (Housing) for HTC EVO 3D
    07-07-2011 09:37 AM
  10. oasis9389's Avatar
    dam 40$? that is steep
    07-07-2011 09:38 AM
  11. thatwilsonguy's Avatar
    Yep, thats the same one I found. Again, too much. You might try an authorized sprint repair center.
    07-07-2011 02:03 PM
  12. deejaycrash's Avatar
    That site sells both front and rear chassis and the battery cover also for $80
    07-07-2011 07:30 PM
  13. solo1's Avatar
    OEMs ALWAYS cost more than a suitable third party replacement ... And that goes for EVERYTHING ... Try Buying an OEM part for a BMW ... Makes you wanna cry like a baby.
    07-07-2011 07:39 PM
