ah ok cool good to know. My Photon allows mirroring of whatever is on the phone's screen. Good to know the Evo LTE has the same capabilities. Is there an MHL cable that will allow charging while being plugged into HDMI?
Sweet good to know. Too bad I won't be able to use my mini HDMI cable from my Photon. O well.
Do you need to pull the micro SD card to use the MHL Adapter? What is the solution if you are looking to play a movie that is saved to the micro SD card?
