Uhhh, I just can't believe that so many have bad cameras. My pics are crystal clear and 1000x better that any other phone camera I have used. Maybe there is some kind of protective film over the lens? Has anyone with bad pic images checked to make sure there is nothing covering the lens or that there isn't any smudging on the lens? Something is amiss here and I just don't get it.
Sense not smooth? Really? This is the smoothest interface I have EVER used. I had my E3D over clocked and running ICS with Sense 3.6 and I thought that was super fast. The E4GLTE kills it with the stock ROM! I have over 50 apps installed from the Market and every swipe is sooth as silk! Again, something is amiss here.
Haven't used face unlock but even the Google calls the feature gimicky, so I wouldn't put much stock in it being wonky.
No mass storage? I've had mine connected to my PC all day, dragging and dropping files all over the place. Now, the interface on the phone has changed, so things are arranged a little differently, so allow me to explain how it worked for me. When connected the phone brings up the "Choose a connection type:" screen.
Click to view quoted image
Before you would select the big box in the upper right to connect as a drive. Now the selection is below. Just click the radio button next to "Disk Drive" and it should pop up a drive in Windows! It was that easy for me. Direct access to the SD card. I've been moving music and movies to it all evening and it works perfectly.
