5 row icons without using custom rom?
n4cer26
5
I am rooted and would like to have more icons on each screen. Is there a way to do this? Also would like to add more screens for icons.
kbp08tls
465
97
Just about any home launcher in the Play store will let you customize the number of rows/columns and number of screens. Nova and Apex are the top right now for ICS. The only drawback (some would say advantage) is that you lose Sense widgets, but there are numerous replacements available in the market if that's your thing.
mggm100
109
You can also place up to 16 icons in a single folder.
Sent from my EVO 4G LTE using Android Central Forums
Glenn
389
44
I haven't used it since switching from the OG Evo to LTE, as it's got a much improved folder system, but if you want to be able to access the apps directly without having to open the folder first, you can give Multicon Widget a try.
Reactions: crxssi
crxssi
Linux: The power beneath
May 31, 2010
2,668
155
That is just a super find! It works really well too. Only thing odd is the lack of horizontal widgets, there are only vertical ones.... If he can change the widget program to make the thing ICS re-sizable, that would really be "wow".
Glenn
389
44
I thought he had multi-column widgets available, but I guess I just remembered wrong...
He hasn't updated the app in a long time, but was pretty responsive to email suggestions when I contacted him, so maybe you do the same.
educationalco22
