1. htcevoLTEgirl101's Avatar
    Help!! I have no idea what is going on with my Evo 4G LTE! I barely got it about 5 days ago. I downloaded HTC Sync Manager on my computer because I wanted to put some songs on my phone from my computer. I connected it and everything was going fine but when I tried syncing it said that there is no SD card in my phone. So I took the back off my phone and checked and there wasn't a SD card in there. I put the back, back on my phone and all of a sudden in the top right hand corner a bunch of words started running and it still is going. I tried restarting my phone and everything, nothing is working. Please someone help! I put a screenshot up... has anyone seen this before? Can someone help fix this for me? Thanks! Need help asap!
    08-12-2012 03:54 AM
  2. zmann's Avatar
    Don't panic,, I seen someone helps someone else with this once. It is a setting in the developer options I think. Someone should know.
    Sent from my EVO 4g lte
    08-12-2012 07:03 AM
  3. zmann's Avatar
    Go into developer options and see what is checked. I just checked mine and only "animations" is checked.
    htcevoLTEgirl101 likes this.
    08-12-2012 07:05 AM
  4. htcevoLTEgirl101's Avatar
    Thanks your awesome! Show CPU usage screen overlay was checked so I unchecked it and my problem was solved. I just got this phone so I'm still getting use to it.. so far I love it though. Again thank you your awesome!
    Sent from my EVO using Android Central Forums
    zmann likes this.
    08-12-2012 01:09 PM
  5. zmann's Avatar
    No problem, glad I could help. I just remembered someone else helping someone else with same issue. That's why I love these forums,, you learn something new everyday.
    08-12-2012 01:15 PM
  6. DisplacedMic's Avatar
    haha - wow - that's nuts. i would have panicked too!
    glad you got it fixed
    08-12-2012 07:34 PM
  7. htcevoLTEgirl101's Avatar
    Yeah you saved my phone lol.. i was about ready to take it to Sprint.. glad I didn't have to, thanks to you. And yeah this forum is awesome! I know if I have any questions about my phone I know where to go now! How long have you had the EVO 4g LTE?
    08-12-2012 10:36 PM
  8. htcevoLTEgirl101's Avatar
    I was panicking, I just got the phone like 6 days ago too.. I'm so happy I didn't have to take my phone in.. sprint would have made it more difficult than need be. If I can avoid having to deal with Sprint customer service the better for me!
    08-12-2012 10:38 PM
  9. zmann's Avatar
    I have had mine for 3 weeks now,, I really like it. I had all the EVO's, liked them all.
    08-13-2012 05:45 AM
  10. Kizzmocat's Avatar
    Is this some sort of phone geek flirting? Sure seems like it, just cut to the chase and ask her out! Lol, and God luck kiddies
    PreMo15 likes this.
    08-15-2012 11:47 AM
  11. zmann's Avatar
    Huh? I must have missed something here.
    08-15-2012 02:20 PM
