1. Darth Mo's Avatar
    Less then four months and power button is already wonky. Replacement on the way so whatever.
    It works eventually, but it's pretty annoying. Is there an app out there that will let the volume rocker or camera button wake the phone?
    I'm not rooted.
    09-19-2012 05:41 PM
  2. kronosqq's Avatar
    I'm not rooted.
    Don't know of any way to do it on a non-rooted device. If you root though, most of the roms over at xda seem to have that kind of functionality built in.
    Sent from my EVO using Android Central Forums
    09-19-2012 07:08 PM
  3. Zstephen's Avatar
    Yes, there is an app in the play store called fix broken power button,I used it when my ns4g power button failed, no root required
    Sent from my Nexus S 4G using Android Central Forums
    sony Bror likes this.
    09-19-2012 07:33 PM
  4. Mom2Ninjas's Avatar
    https://play.google.com/store/apps/d...il.fixbrokenpb
    No support from the developer anymore though.
    09-20-2012 06:28 AM
  5. hburn5574's Avatar
    Try Awesome On Off. You don't use your power button and it will bypass the lock screen (no root required either). I've been using it for a couple of months now and I really like it.
    Sent from my HTCEVOV4G using Android Central Forums
    09-20-2012 06:43 AM
  6. Darth Mo's Avatar
    Yeah no developer support and it makes no mention of Android 4.0. I'll pass on that one for now.
    09-20-2012 10:21 AM
  7. Zstephen's Avatar
    Retracted, haven't used it in a while, my b
    Sent from the year 252525
    09-20-2012 12:51 PM
  8. Andras's Avatar
    Is there any way to make it not so sensitive?
    09-20-2012 03:28 PM
  9. rsk2mc's Avatar
    Root it, mean rom wakes with camera button
    Sent from the blob fish (if you don't know what a blobfish is, Google it)
    09-20-2012 07:05 PM
  1. Is there any way to change the home button options?
    By Soundtrack to Chaos in forum Samsung Galaxy S3
    Last Post: 12-09-2016, 06:48 AM
  2. Any way to make phone feel more 'premium?'
    By aandrewalv8 in forum Samsung Galaxy S3
    Last Post: 07-08-2012, 03:15 AM
  3. Any way to silence phone announcement "droid" on startup ??
    By rorkin in forum Verizon Droid Charge
    Last Post: 05-26-2011, 11:10 AM
  4. Any way to root Epic with out plugging in phone?
    By dannynyc in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 03-28-2011, 08:39 PM
  5. Easiest way to exchange phones with VZW?
    By Strygun in forum Verizon Droid Incredible
    Last Post: 05-06-2010, 09:30 PM
