So I bought a used Evo LTE a few weeks ago.. I finally found one that was basically brand new. Still, I went through every inch of it making sure it didn't have any issues. It didn't have any, so I thought... That night though when I was playing with it, I realized the camera wasn't focusing at all. When you tap it to focus it makes the sound that is supposed to tell you it is focusing, but it doesn't focus.
Things I've tried:
I did do a ##786# reset as soon as I got the phone, and again after I realized the problem. Also, I have set the camera to default settings. I have also downloaded every single one of the aftermarket camera apps, testing the focus on each of them, nothing seems to get it to focus. This is only a issue when I try to focus on close up type of pictures, like text on a computer screen or anything within about five inches from the camera, (otherwise the camera works great). I did notice after looking at the camera itself that there is some kind of shiny paper thin material that after popping the back sd card cover off, and examining it closer, seems to be some sort of spacer between two plastic parts of the camera assembly. It has slipped out of position, but it is not far enough out of position as to block the view at all, but its there. I wondered if maybe this was the problem or just coincidence.
My question is..Isn't the focus completely digitally controlled? There are no moving parts that make it focus, right? I wondered if there were, and maybe this out of place spacer is preventing it from moving? Do you think a update to the software might fix this? If there are no moving parts, it has to be software , right? I have searched the forums and web high and low, but can't seem to find any answers regarding the above.
Things I've tried:
