I made this mistake on my wife's LG optimus accidently formated her SD card so I erased her Rom but thankfully I though of the easiest thing all I did was downloaded her ROM on my SD card pulled her SD card out and put mine in hers and the booted in recovery and flash the Rom from install zip from SD card . So simple if you have ways to put stuff on your SD card .
Sent from my HTC EVO 4G Tapatalk
I was able to load a sprint lovers rom on the sdcard, but when i tried to boot phone it still didnt work. it says that there is no pc36img on the phone for diag.zip,diag.nbh or pc36img.zip, or pc36img.nbh. how do i get that on the phone? i downloaded a pc36img.zip with radios and wimax and put it on root of card. when i boot into bootloader it never sees the pc36img and prompts for update. When i load the sprintlovers rom it loads all the way to sd install complete. but if i load any other rom I get: " installation aborted" assert failed: write_raw_image("/tmp/boot.img)
E:error in/sdcard/mikg-v2.45-signed.zip
Status 7.
What does this mean...? I see that this is RA recovery.
What to you think i should try next?
