1. pinkdymonds885's Avatar
    I installed the miui.us rom version 1.12 and now when I click to go to front camera, I just see a green screen but when its the standard way its fine. Any help please??
    Sent from my PC36100 using Tapatalk
    12-14-2011 05:39 PM
  2. AlphaTango414's Avatar
    Reflash/install app
    DumpedDuce Approves This Message Via HTC Evo 4g
    pinkdymonds885 likes this.
    12-14-2011 10:41 PM
  3. pinkdymonds885's Avatar
    thanks , it worked
    12-15-2011 11:19 AM
  4. AlphaTango414's Avatar
    thanks , it worked
    Np had the same problem first time I flashed it.
    12-16-2011 12:53 PM
  5. playaz1's Avatar
    you can always dial the front camera down a few notches in the settings. i think its suppose to be 640x480 and your good to go
    12-22-2011 05:45 PM
  6. isabella cortez's Avatar
    Reflash/install app
    hoe do you do that ?
    07-19-2015 07:47 PM
