A acuracing Member Apr 28, 2010 10 0 0 Visit site Jun 6, 2010 #21 *#*#4636#*#* Battery Information Battery Level = Your %
F frank828#AC Well-known member May 27, 2010 61 0 0 Visit site Jun 6, 2010 #22 i'm using Battery Indicator that i got for free from the market. it gives you the temp, batt percentage and voltage.
D dark_dj27 Well-known member May 29, 2010 73 0 0 Visit site Jun 6, 2010 #24 Re: Exact battery percentage on the EVO Battety status free from the market is good to it lets you put a little battery icon in the notification bar with the percentage in it Sent from my SPH-M900 using Tapatalk
E eyecon82 Well-known member May 26, 2010 1,542 62 0 Visit site Jun 6, 2010 #25 vizBattery gadget is by far, the best looking one out there
L lembowski Well-known member Nov 17, 2009 519 26 0 Visit site Jun 6, 2010 #26 There is an HTC widget for this on the market. Its name is "Battery Widget".
C Cory Streater Well-known member Sep 21, 2009 9,495 3,428 0 Visit site Jun 9, 2010 #27 Threads merged.
I inco9nito99 Well-known member Jun 18, 2011 52 0 0 Visit site Jun 24, 2011 #28 still looking for something that REPLACES the stock status bar indicator with a percentage. Preferably free and/or doesn't drain the battery lol.
F firecaptain Member May 17, 2010 20 0 0 Visit site Jun 24, 2011 #29 inco9nito99 said: still looking for something that REPLACES the stock status bar indicator with a percentage. Preferably free and/or doesn't drain the battery lol. Click to expand... There is a hack you can flash through recovery. Find it at dev. I just installed it yesterday and I got rid of my other battery app Cyphered out on my EVO while I'm out and about.
B bzxzlg Well-known member Jun 5, 2010 58 0 0 Visit site Jun 24, 2011 #30 I think the one that FireCaptain is refering to can be found at: [MOD] 1% Battery charging and use for GB OTA Update #8 4.22.651.2 - xda-developers
F firecaptain Member May 17, 2010 20 0 0 Visit site Jun 29, 2011 #31 Right. Thanks for linking it. I meant to go back on my computer and find the thread and link it, but I forgot...haha Cyphered out on my EVO while I'm out and about. Actually after clicking through to your link, that wasn't the one. Same concept tho. I'm actually using the UOT one - here. Last edited: Jun 30, 2011
S stktd New member Dec 23, 2011 2 1 0 Visit site Dec 23, 2011 #32 Try using Battery Percentage & Temp , it has your available ram on it too https://market.android.com/details?...EsImNvbS5ub3RpX2ZyZWUuc2Yubm90aWZpY2F0aW9uIl0. and its free
O onixblack Well-known member Jun 2, 2010 158 11 0 Visit site Dec 23, 2011 #33 I use Battery Notifier (Big Text) as a way to tell from my notification bar https://market.android.com/details?...51bGwsMSwyLDEsImNvbS5sYXJyeXZncy5iYXR0ZXJ5Il0.
