1. itzhobbes's Avatar
    For some reason when I try to update my status on friend stream it says that it's unable to update facebook please try again later. It's been doing it all night so far. I've done clearing the data from the Friend Stream app and then removing the widget then removing facebook account and turning off the phone. Then I turned it back on, logged back into facebook and put the app back on the screen. No Luck. Any other users experiencing this?
    07-09-2010 02:49 AM
  2. scoobdude's Avatar
    did you try the regular fb app or getting on via the browser?
    07-09-2010 03:34 AM
  3. itzhobbes's Avatar
    The app and via the browser it works. It just through friend stream it doesn't seem to work when earlier in the day it did.
    07-09-2010 03:56 AM
  4. scoobdude's Avatar
    maybe try and clear the cache?
    07-09-2010 07:13 AM
  5. jeffro77's Avatar
    I am experiencing the same issue, and can confirm that it just started happening yesterday. I'm also finding that the widget works fine for Twitter, and I'm also seeing that if I try to launch the actual FriendStream application, it force-closes.
    I also noted yesterday afternoon that the Facebook web interface changed slightly (e.g., I now see user thumbnails on my notifications). I wonder if Facebook updated their APIs, and FriendStream is having trouble talking to the Facebook servers?
    07-09-2010 02:05 PM
  6. jeffro77's Avatar
    OK, on the basis of a thread at HTC ( Friend Stream/ Facebook Problems After 1.47.651.1 update 06/28 - HTC EVO™ 4G (Sprint) - Android Forums - HTC Community ), this fix worked for me:
    Home > Menu > Settings > Accounts & sync > Facebook for HTC Sense
    Remove account, confirm remove
    Add account > Facebook for HTC Sense
    Populate login credentials, tap "Sign in"
    Close out of settings and take a look at FriendStream
    I hope this works for you, too.
    batsai#IM and MinistrOfJustiz like this.
    07-09-2010 02:13 PM
  7. batsai#IM's Avatar
    Thanks Jeffro, that did the trick!
    07-09-2010 02:52 PM
  8. youngzayiles's Avatar
    Yeah I had the same problems above and I followed the steps rebooted and then hit that little arrow on frindstream and it worked again...
    07-09-2010 03:20 PM
  9. justinsaneeeee's Avatar
    Yea this did not work for me I deleted the accound then added it again and it still says forceclose ive had this problem since I got the phone if will update once when i master reset it then after that it will not update.
    07-29-2010 07:40 PM
  10. Ether2's Avatar
    I did same but in my case it is saying "The service is currently unavailable. Do you want to try again?" evertime i press yes it shows again and again. Please help me anyone, I need the phone numbers of my friends......
    11-18-2013 10:47 AM
