Now that more time has passed I am going to reset the poll to get a more accurate calculation. I would believe the results will be much different this time around.
At the time of the resetting the current count is 18.86%(73ppl) yes to 81.14%(314 ppl) no
Vote yes or no so we can see how common this is
P.S. Sprint will fix this for free within 1 yr of purchase
My launch day EVO just cracked today. My guess is that this will happen to most EVOs eventually since the plastic is pretty brittle and there are definitely a few weak spots.
I am curious how exactly Sprint fixes this. Wouldn't they have to replace the full bezel?
They replace the whole front of the phone. When I took it in they said it was a known issue and that it would be fixed for free. They fixed mine. Same phone just replaced the front.
Not a "known issue", like the charging port issue. But it is one of the top 3 things that we see. (cracked screen, charging port, rocker cracks) it is covered under TEP or ESRP as minor physical damage.
So does that mean we don't need to have insurance to get it fixed?
Maybe at your store it was not considered that, but here in AZ I haven't been in one Sprint tech store that said it wasn't a known issue. Just about every store said they fix this problem quite often. It also is not a physical damage case either. It was considered faulty hardware at these stores. Because the user does not cause these stress cracks.
When I took my phone in to my sprint store it had the cracks white spots on the screen and charging port was failing, it only took 10 min for them to tell me to come back in a few days for my replacement.
If they fix this for free this will be my 3rd trip to the service centre. Thus means ill be eligible for an advanced upgrade, meaning I can upgrade to the evo shift for FREE. And still have my regular upgrade in august.
YES.
I hope you get the shift, ill be getting it most likely and you will be a great asset to the forums over there
Mine has the cracks and I can peel back the little part above the volume rocker.
I just got back from the Sprint store down the street and they told me they couldn't replace it because it's not a known issue and it's only cosmetic and doesn't affect the phone use. They also told me it would require changing the whole screen (a part that the also conveniently didn't have).
I have a feeling one day the whole part is going to break off when it gets caught on something.
I may try a few stores to see if one of them will change it for me under my insurance plan.
Yeah I just got off of the phone with Sprint and the guy on the line said the same thing. He sarcastically said "another great experience at a Sprint Store" and then went on to say I could go to 3 different stores and get 3 different responses. I'm going to go to another store later in the week.
You could always just crack the screen. They have to replace it at that point. And it's covered for free if you have service and repair.
If you go to 3 stores, perhaps you'll find a good one. They are certainly out there. It's a 5 minute process to pull out a phone going back to the warehouse, remove the screen, and place it on your device. Why some techs wont do it is beyond me. It also makes money for their store since Sprint pays them for the repair.
That would be a down grade as it has a 800mgz cpu no front cam and all... i would then get the epic if you want the keyboard. 2.2 should be out soon for it. but the epic is not going to be end of life as they are now dropping the price and samsung said a new version with duel core cpu will be out.
Well I went to one corporate store and they said no, that it requires changing the whole screen and they wont do that. I said "well what if I drop it and the screen is broken - then you'd have to change it." He said yes but we don't have the part. Then I went to another store with a repair center that was not a Sprint corporate store and he said he'd do it but the broken ones to harvest from all have the same cracks, he'd have to give me a new phone but they're on back order. He said to follow up weekly in the next 2 weeks.
I had just got my phone 3 1/2 weeks ago and I just love looking this phone and yesterday I saw this crack by the power button is just like in the picture and I got super pissed I said to my self what the **** man really its tiny but if I could get it fixed so I will to go see I live down the road from a sprint store so well see
Its bull but I'm in love with phone and I hate for it to look like **** and I tried to cover a day after I got the phone I didn't like how the phone looked
