I'm having a problem with my Shift maintaining a USB connection. When I connect and mount as disk drive, it connects just fine. But frequently after a few minutes it will revert back to "charge only" on its own for no apparent reason. If I pull down the menu and connect as USB again, it mounts again just fine. Sometimes it will stay connected, sometimes it will again after a few minutes switch back to "charge only" for no reason.
Any ideas what could be causing this? It's a bit annoying.
