I just switched from AT&T to metroPCS and i unlocked my htc first. I found a few versions of what the apn settings need to be, however I cannot get LTE. Am I screwed because its not a MetroPCS phone?
It has a 1700 band capability which is T-Mo's...It should work. Can't you get MetroPCS to help you out? They should be pretty eager to get it set up properly. Our you sure where you are at its available?
