1. FASTEDDIE427's Avatar
    I just switched from AT&T to metroPCS and i unlocked my htc first. I found a few versions of what the apn settings need to be, however I cannot get LTE. Am I screwed because its not a MetroPCS phone?
    11-13-2013 01:30 PM
  2. Chex313's Avatar
    It has a 1700 band capability which is T-Mo's...It should work. Can't you get MetroPCS to help you out? They should be pretty eager to get it set up properly. Our you sure where you are at its available?
    11-13-2013 08:20 PM
  1. Replies: 1
    Last Post: 04-23-2014, 06:49 AM
  2. galaxy s4 crashing applications ..help
    By Anchit Sharma in forum Legacy Android & Other OS's
    Last Post: 04-05-2014, 05:09 PM
  3. This is a tough one. Need your help.
    By longtime44 in forum Legacy Android & Other OS's
    Last Post: 11-14-2013, 06:45 PM
  4. Help please! Note 2 won't turn on after a fall
    By Maanoonaa in forum Samsung Galaxy Note 2
    Last Post: 11-14-2013, 05:44 PM
  5. adding a APN to mobile networks
    By Brittany Becker in forum Samsung Galaxy S3
    Last Post: 11-13-2013, 04:02 PM
