1. xeron72548's Avatar
    Hello,
    I had put my phone to charge and when I came back to it 10 minutes later, it was off. I tried turning it back on but to no avail. The charging light will also not turn on. I cannot get into hboot or get my computer to recognize it. Please help!!
    07-27-2013 10:31 AM
  2. chrisxpierce's Avatar
    Try plugging into your pc, and not a wall outlet. Try a different wall outlet. Try a different USB Charging cable. Other than that, you'll need to contact HTC Support.
    07-27-2013 10:38 AM
  3. xeron72548's Avatar
    I have done all of that. I have contacted them and they said I would have to send it in. However, since my bootlader is unlocked, I don't know whether they will accept it or not
    07-27-2013 10:41 AM
  4. akd1217's Avatar
    I had a similar problem the other day, different phone. If a soft reset, popping the battery out and back in, using different outlets doesn't change anything, try using a car charger. It seems to have more power to jump start the charging process of an absolute dead phone. Be warned, though, it worked and so does my phone, but I am currently working out my phones problem of not being able to charge with a wall charger at all now.
    07-27-2013 10:50 AM
  5. Scott Kenyon's Avatar
    People have been successful with warranty claims having unlocked bootloaders. I'd send it in and see what happens.
    Sent from my HTC One using Mobile Nations mobile app
    07-27-2013 10:58 AM
  6. xeron72548's Avatar
    The HTC One does not have a removable battery
    07-27-2013 11:19 AM
  7. akd1217's Avatar
    Gotcha. I didn't know for sure, but my RAZR doesn't have a removable battery either. The car charger still got it to charge and turn on when nothing else would though. Hope it helps.
    07-27-2013 12:56 PM
  8. malikshuman's Avatar
    Try holding your power button for 15 secs. It simulates a battery pull
    07-27-2013 12:58 PM
  9. jomescala36's Avatar
    Hey! Guy's How to fix my phone because it wont turning on
    12-14-2013 09:34 PM
  10. nhallyma's Avatar
    hello
    my phone's battery ran down and i had to connect it to power as usual,but after some time it went off and didnot power on again except when i connect it to power,it only flashes ared light at the top.whats wrong?
    01-28-2014 04:43 AM
  11. nhallyma's Avatar
    hello
    01-28-2014 04:46 AM
  12. HyperYT's Avatar
    There’s a very better, easier and safer method i know to fix this.
    (Only works on Samsung devices somehow))
    Requirements:
    A PC or Laptop
    An MD5 File of the original firmware of your device
    Odin app
    USB
    Download Samsung drivers
    Okay.
    1. Press and hold volume down and power button of your device
    2. wait until the model name shows up
    3. now DONT release any buttons. press and hold home button
    4. When download mode shows up, release all buttons and press volume up
    5. Open Up Odin and then connect USB to ur PC
    6. Select AP or PDA button on the Odin window
    7. find your MD5 File
    8. wait for it to scan and then press start!
    9. wait for everything to finish and now ur done!
    09-11-2016 01:26 AM
  13. Mary Ball's Avatar
    Thank you so much, this is how I got my phone to turn back on. Guess I wasn't holding it long enough.
    01-05-2017 04:15 PM
  1. Tether Fonepad to my laptop on AT&T
    By kinged33 in forum ASUS Fonepad
    Last Post: 12-23-2013, 09:34 AM
  2. Cannot get the update after unrooting phone
    By Jarrid Duchnowski in forum Droid RAZR M
    Last Post: 08-08-2013, 01:10 AM
  3. Recover Photos From Bricked Phone
    By jcgsville in forum T-Mobile Galaxy S II
    Last Post: 07-27-2013, 11:09 AM
  4. Latest update glitched up my phone.
    By mepres94 in forum Droid RAZR M
    Last Post: 07-27-2013, 11:08 AM
  5. White Light "of Death" Deleted SD Pics and Music. Please help!!
    By akd1217 in forum General Help and How To
    Last Post: 07-27-2013, 10:28 AM
