Tunein radio problem
Patrick Williams13
51
Running stock and last few days tunein just stops as it's streaming and I have to go back into the app and press play again. Always happens when screen is off. Any ideas?
puch96
880
31
28
There could be something wrong with the TuneIn service. Also, I noticed that it recently received an update, and sometimes updates can screw things up.
Try clearing data and force stop the app. If that does not work, clear data, uninstall the app and re-install and see if the problem persists.
jhilker
Trusted Member
Sep 21, 2009
1,675
651
113
I have the pro version from the Amazon Appstore, and have noticed it doesn't play well with Bluetooth in my car. No problem with headset, though.
Sent from my HTCONE using Tapatalk 4
abk8445
I just recently have the same problem. 10 days ago, for over a year, I was listening to radio stations for hours. But now, few seconds after the screen goed dark, the station stops. I have searched the settings of both my system and the Tunein. Did not find anything that could solve the isse. I also think that it is the problem of the newest update that screwed up the app. I expressed this to Tunein, but they say the update should be fine. I have a Samsung Galaxy S2.
jfs101
Trusted Member
Sep 17, 2011
301
Go into settings and look at the options for better streaming. I use this app every day without a hitch.
abk8445
Hi jfs101,
I cannot see or find "option for better streaming". Could you please let everyone know where to find this option? Maybe this is the key. Thanks.
One thing I found is that when the screen goes off, the device automatically turns the WiFi off, although in the setting it says to stay on WiFi when screen is off. I realized that whenever the screen and WiFi turns off, the device uses Internet and this disconnects tunein Radio. When I turn the screen on, WiFi kicks in and Tunein radio starts to work. I could not find how to prevent switching. I even showed this to the T-Mobile crew who could not figure oure why the device does it. Thanks.
legaldeejay
79
There is a setting in the Tunein app to Disable Auto-Lock. Make sure that is checked. This should prevent the stream from stopping when the phone goes to sleep.
jfs101
Trusted Member
Sep 17, 2011
301
Hi jfs101,
Increase the buffer, go for a 30 seconds buffer and you should be sailing smoothly from there on.
myrealtygal
11
Nothing wrong with the apps or with bluetooth connection. Every radio app I used quit after a couple of mins, Talk Stream Live, Pandora, SirusXM, iHeart Radio, etc. whether on bluetooth or on Note 5 internal speakers.....frustrating as Hell! Someone on forum suggested to quit "power saving mode",,,,so far no interruptions! THANK YOU!!
steve1084
