I searched through all the forums and I couldn't find anyone with this problem. My phone got water damaged a couple days ago so I kept it in rice for 48 hours. Now, my phone will only work when charging. Once I unplug it, it could be at 74% and then shut off for no apparent reason. I try turning it on and it won't turn on. Then, I'll plug it back into the wall and it will say the battery is at 0%. Is my battery ruined forever or would keeping it in rice some more fix it or is there a different fix for this? Thanks in advance.
