1. Baz Halsall's Avatar
    Anybody had this issue
    02-08-2015 08:20 AM
  2. Golfdriver97's Avatar
    What version of Android? Did you get 5.0?
    02-08-2015 08:57 AM
  3. soshi89's Avatar
    Is it greyed out but not able to select or the option itself isn't visible? If you have max performance enabled in developers mode on it will be greyed out and disable the option to turn on power saving on extreme power saving mode.
    02-08-2015 09:02 AM
  4. vmnoodle71's Avatar
    you must attempt to recheck for updates and bug fixes
    02-10-2015 06:29 AM
  5. DJM77's Avatar
    I had the same issue. In developer options I had "high performance " enabled, just disable it and you will have both power saving options enabled again.
    kct1975 likes this.
    02-27-2015 02:28 PM
  1. How do I upgrade 4.2.2 to 4.4 KitKat on my phone?
    Last Post: 02-08-2015, 11:56 AM
  2. Replies: 1
    Last Post: 02-08-2015, 10:37 AM
  3. Replies: 1
    Last Post: 02-08-2015, 10:30 AM
  4. How do I stop my HTC One M7 from restarting again and again?
    Last Post: 02-08-2015, 09:37 AM
  5. Replies: 1
    Last Post: 02-08-2015, 07:48 AM
