1. Senthilkumaran Sundaramurthi's Avatar
    Hi All,
    I've got a HTC one m8 and I have trouble connecting it to the car's handsfree.
    Mobile - HTC one M8, Android Lollipop - 5.0.1, software version - 4.18.720.8
    Make - Ford, Model - Falcon, Manufacturing year - 2013
    Problem
    When I scan for devices my phone scans for quite a long time and
    shows the bluetooth address(probably) of the handsfree. when I connect,
    a 16 digit key is requested whereas the handsfree shows 4 digit passkey.
    Observation
    Somewhere I read that I need to enable some options in advanced. But i dont
    see an advanced option in Bluetooth. I tried to pair it with my windows laptop
    and it works like a charm.
    Your responses would be highly appreciated.
    Thanks.
    SSk.
    idrees.kaka26 likes this.
    06-22-2015 09:45 PM
  2. IAmSixNine's Avatar
    Let your device scan longer.
    I have often seen the mac address show up for a device but if im patient it will then switch to the devices name instead. Once the name shows i then try to pair.
    I have a ford F150 and my M8 synced fine with it.
    Also you might want to check with the ford site and make sure the software in your cars media device is up to date.
    I got my truck new a few months ago and it needed 3 updates.
    06-23-2015 10:03 AM
  1. Replies: 1
    Last Post: 06-25-2015, 09:38 AM
  2. Can I get some help with a Note 3 Lollipop update problem I am having?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 06-25-2015, 09:31 AM
  3. Case to help G4 lay flat
    By R_Kell628 in forum LG G4
    Last Post: 06-23-2015, 08:15 PM
  4. Streaming devices... Which one??
    By robert7107 in forum Ask a Question
    Last Post: 06-22-2015, 08:03 PM
  5. Samsung galaxy tab pro 8.4 battery
    By Bni Kean in forum Ask a Question
    Last Post: 06-22-2015, 07:33 PM
