1. mikeyboy80's Avatar
    I've been setting up my new device and have got the the weather on my lock screen but worried that this will cause battery drain? I've set the weather change interval to be six hours but wondered shall I turn this off completely as it could have an impact on the battery?
    07-18-2015 07:17 AM
  2. PapaGary's Avatar
    On my Motorola Moto X with the Weather Underground widget the battery drain is minimal to nonexistent.
    Try it and see. Experiment with the various settings. You're not going to blow it up.
    Mine is set to "Update as needed".
    kilskev likes this.
    07-18-2015 07:27 AM
  3. Mooncatt's Avatar
    Any app syncing will use battery power. I have it disabled because I prefer Weather Bug instead, but I suspect the drain would be negligible.
    07-18-2015 10:40 AM
  1. New Battery, Old Problem
    By BarbaraDG in forum Samsung Galaxy Tab S 10.5
    Last Post: 07-27-2015, 08:08 AM
  2. My profile in Messages app
    By JoLyn Wahrenbrock in forum Samsung Galaxy S5
    Last Post: 07-18-2015, 06:33 AM
  3. How can I identify this unknown app?
    Last Post: 07-18-2015, 06:24 AM
  4. Outlook App not archiving messages
    By MisterEd in forum LG G3
    Last Post: 07-18-2015, 06:22 AM
  5. Why don't I have internet?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 07-18-2015, 05:29 AM
