Why 'Android System' singly drains my battery so extremely fast?
Hi guys
I have HTC One M8. Android System drains my battery in an unbelievable way. I did a reset factory and charged it 100%. Then I powered it on and after 6 min while the screen all of the time was off, the battery got 98%. In the following, I turned off the screen again and incredibly after 21 min without any usage the battery got 94%.
I really don't use the phone and the battery drains such this. Just guess what happen if I turn on screen and use it?!!! I really confused. I took 2 shot. Pls check them out.
(When I charge my father's G3 after 5 min using wifi the battery is 100%! Still no 99%!)
http://i.imgur.com/J8381SL.png
http://i.imgur.com/04GVOr6.png
http://i.imgur.com/BqgKPZj.png
http://i.imgur.com/pm9uDPN.png
Re: Why 'Android System' singly drains my battery so extremely fast?
Welcome to Android Central! The problem with figuring this out is that Android System could represent something the system is doing, or it could also be a 3rd party app that's utilizing some part of the system. The first thing to try is booting into Safe Mode: https://support.t-mobile.com/docs/DOC-10853. If the battery drain goes away, then I'd suspect some app you installed is inappropriately utilizing an Android System component.
