01-09-2018 12:04 AM
34 12
tools
  1. anon(9785393)'s Avatar
    Excellent, thanks for the report! That's exactly the one I was thinking about buying, and it's great to hear that it works. Have you noticed any decrease in sound quality compared to goint straight out of the phone via the USB-C to 3.5mm adapter?
    That was my concern too.
    08-07-2017 05:00 PM
  2. oooitzalex's Avatar
    Buy this. Well worth it and it has a warranty
    http://forums.androidcentral.com/e?l...token=SAaH_19g
    09-19-2017 03:38 PM
  3. nileshdd's Avatar
    http://forums.androidcentral.com/e?l...token=RaNlu9BP
    It's out of stock.
    09-19-2017 04:39 PM
  4. Malchore's Avatar
    The original poster is looking for something like this: https://www.amazon.com/Headphone-Ada...cUvbUpU6001110
    A simple 2-in-1 usb type-c splitter cable. There are several adapter cables like it, and most of them (likely) won't work with the HTC U11 - they are meant for the Moto Z line of phones.
    I have a HTC U11 and don't have BlueTooth support in my car so I'm in the same boat. Since audio quality isn't so important to me while driving -- I mostly listen to Podcasts anyways if I'm driving -- I went with a BT Adapter solution. I got one that has a battery in it, because I can't stand cables running all over my car seat while I'm driving.
    10-02-2017 10:23 AM
  5. Malchore's Avatar
    wynand32 - I bought this device a few days ago ( https://www.amazon.com/gp/product/B0...cUvbUpU6007517 ) and it works fine for me.
    10-06-2017 10:50 AM
  6. wynand32's Avatar
    wynand32 - I bought this device a few days ago ( https://www.amazon.com/gp/product/B0...cUvbUpU6007532 ) and it works fine for me.
    Thanks, I'll check it out.
    10-06-2017 10:54 AM
  7. nileshdd's Avatar
    Tried a few products on Amazon that didn't work, got discouraged, someone on XDA said this adapter worked, so I gave it a shot, and I can confirm it works with the HTC U11! It does not work with the USB-C headphones included however, but if you use the USB-C to 3.5mm adapter, then you can use that with this hub and you will be able to charge (and quick charge) while listening to headphones.
    https://www.amazon.com/dp/B01N0R1F1M...cUvbUpU6011434
    Hi Marsui
    I bought this adapter but I am not able to get both 3.5mm headphones or the charging to work.
    1) Charging - I see 2 options on the phone when I connect the adapter - Use usb for a) Supply power to the adapter b) charge the phone. I selected b) multiple times but it doesn't switch and the charging doesn't start. It keeps providing power to the adapter.
    2) the headphone is not even detected and all music plays through phone speaker (of course).
    Anything that can help?
    Thanks so much
    Nilesh
    10-08-2017 08:31 PM
  8. nileshdd's Avatar
    Bumping this for help.
    10-10-2017 11:42 AM
  9. jwbekens's Avatar
    This will solve all your problems. I am waiting for the final production. Should be ready any day now.
    https://www.bluewaveaudio.ca/?v=7516fd43adaa
    The Bluewave Get arrived today. Wow. Sound is fantastic. Now anyone can charge phone and listen to music at the same time. Can't wait for the Oreo update with aptx HD. Nougat only has aptx. Usonic headphones won't work with the Bluewave Get. Need 3.5 mm headphones. I am using the Harman Kardon headphones that came with my old M8. Just wow. Sure, no noise cancelling, but the sound is amazing. Bluewave pairs with my iPhone 7P, but the U11 bluetooth sound is much better.
    James E1 likes this.
    01-09-2018 12:04 AM
34 12
  1. Nougat update for the G4
    By Oceanic16 in forum LG G4
    Last Post: 12-14-2017, 02:23 PM
  2. Male voice for Bixby
    By Whiskey619 in forum Samsung Galaxy S8 & S8+
    Last Post: 07-22-2017, 08:52 PM
  3. Replies: 2
    Last Post: 07-21-2017, 05:37 PM
  4. Why snapchat lags and is delayed
    By AC Question in forum Snapchat for Android
    Last Post: 07-21-2017, 12:38 PM
  5. Replies: 0
    Last Post: 07-21-2017, 12:37 AM
