This will solve all your problems. I am waiting for the final production. Should be ready any day now.
https://www.bluewaveaudio.ca/?v=7516fd43adaa
Interesting. I'm intrigued
Tried a few products on Amazon that didn't work, got discouraged, someone on XDA said this adapter worked, so I gave it a shot, and I can confirm it works with the HTC U11! It does not work with the USB-C headphones included however, but if you use the USB-C to 3.5mm adapter, then you can use that with this hub and you will be able to charge (and quick charge) while listening to headphones.
https://www.amazon.com/dp/B01N0R1F1...ag=hawk-future-20&ascsubtag=UUacUvbUpU5912620
Excellent, thanks for the report! That's exactly the one I was thinking about buying, and it's great to hear that it works. Have you noticed any decrease in sound quality compared to goint straight out of the phone via the USB-C to 3.5mm adapter?
Buy this. Well worth it and it has a warranty
https://forums.androidcentral.com/e...apter-with-power-pass-through/&token=pxuicB2f
wynand32 - I bought this device a few days ago ( https://www.amazon.com/gp/product/B07437K9ZY/?tag=hawk-future-20&ascsubtag=UUacUvbUpU6007532 ) and it works fine for me.
https://www.amazon.com/dp/B01N0R1F1...ag=hawk-future-20&ascsubtag=UUacUvbUpU6011434
