1. Raeesah0304's Avatar
    Hi Guys,
    My huawei Ascend P7 has stopped Prompting me options when I plug it into my PC or Laptop how do I get my phone to provide these options again?
    04-26-2016 08:40 AM
  2. mstrblueskys's Avatar
    Hi Guys,
    Check your cable. Maybe try a different one. Also, make sure you have the drivers installed on the computer.
    You can also get to that prompt by enabling developer tools. To do this, open settings, scroll to the bottom to About phone, find the Build number, and tap on that a bunch of times. Eventually you'll see a prompt saying something like, "tap x number of times to become a developer." Keep tapping and you'll see a new one that says something like, "Congrats, you are now a developer." You've now enabled the secret dev menu.
    Now hit the back button to go into the main settings menu. Right above About phone, you have a new option to go into Developer options. Under the Networking sub heading you should be able to see the option to Select USB Configuration. That should be the menu you are looking for.
    Hopefully that helps!
    04-26-2016 09:39 AM
  3. Raeesah0304's Avatar
    Hi Thank you so much for the reply,
    I however cannot find the networking sub area it only gives me,
    Debugging
    Input
    Drawing
    Hardware accelerated rendering
    Monitoring and
    Apps
    04-26-2016 10:33 AM
  4. kennyads's Avatar
    If all is working properly and you have your USB lead plugged into your computer with the correct driver installed you should have a notification in the drop down notifications panel which shows the USB logo. It will also show the current status of the connection. Tap to open the menu you require. NB you may find you have accidentally ticked the "don't remind me again" button on this menu. I can find no other alternative way to access this menu.
    08-08-2016 08:52 AM
  1. No Love For The Lenovo Tab 2 A10-70?
    By Old Stoneface in forum Lenovo Android Tablet Discussion
    Last Post: 04-27-2016, 03:16 PM
  2. Replies: 2
    Last Post: 04-26-2016, 05:22 PM
  3. What is this on my background and how can i remove it?
    Last Post: 04-26-2016, 04:22 PM
  4. How can I stop sound on Texts from certain people?
    Last Post: 04-26-2016, 08:47 AM
  5. How bad is sunscreen damage to my Samsung Galaxy S4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-26-2016, 08:28 AM
