Even longer than the s8a?Definitely the best long lasting battery flagship phone.
Really? Every review that I have read shows that it has above average battery life. Link to the reviews showing 4-5 hr SOT?Reviewers says the battery on that is average. 4-5 hrs sot
This is what bgr said :Watched it on YouTube. I don't remember anyone saying it's above average. I think I saw it on UrAverageConsumer channel for example.
Yeah I was referring to the active version which has the larger batteryoh The Active version. my bad. I thought you meant the regular S8. thought the s8a was a typo for s8
For you, it is a good option since it has great battery life, Flagship specs, and you can finance through attDidn't know the Active model had 4,000mah battery inside. I don't hear much about the Active model vs their regular model.
You can always set to trusted devices tied to the Huawei watch that you just won from Android Central.The fps placement ruined it for me
Yes I did, though on my note 8. Works great, I just long press the home button on the aod screen and it unlocks the phoneIs that what you did with the Huawei Watch you won as well ?
It should work for all Android. Whether or not you need to swipe though I think depends on the manufacturer. Samsung does not require it thoughThat's interesting. I'll check this out. Thanks
That's fine, I am just saying that there's a way to get it to work good. Just not sure if other manufacturers implemented it.I don't own any Samsung products lol
