03-19-2018 07:28 PM
108 ... 2345
tools
  1. dpham00's Avatar
    Well, it was for some of us but apparently not enough of us. I'm still using mine a lot and will continue to use it until it no longer works. I switch back and forth now. There are some really nice Android phones. If I could only put Windows on them. Some OEM should have made a phone that you could install the OS of your choice.
    Well htc made a phone in Android and windows versions... That was a flop though
    11-16-2017 05:44 PM
  2. dpham00's Avatar
    You can try to make your Android into a windows experience by following this set up
    https://www.google.com/amp/s/www.and...-android%3famp
    That has some great tips for those transitioning from wp to Android.
    11-16-2017 05:45 PM
  3. Aljean Thein's Avatar
    Oh that's better. But didn't picked up that well compared to the new dock for the s8 and note 8
    11-16-2017 08:59 PM
  4. Aljean Thein's Avatar
    Yes, these are nice !
    11-16-2017 09:00 PM
  5. SaltFreeAndroid's Avatar
    Has anyone used the desktop mode for a week or a significant length of time? I use Cloudready and I'm curious if I would notice any difference.
    11-19-2017 03:35 PM
  6. dpham00's Avatar
    Oh of course it's not as good as the dex. Just saying that Samsung had one before.
    11-20-2017 05:26 PM
  7. Aljean Thein's Avatar
    Don't think the software was ready for it either
    11-20-2017 05:35 PM
  8. dpham00's Avatar
    Perhaps. Maybe they didn't spend enough time tweaking it back then
    11-20-2017 08:21 PM
  9. Aljean Thein's Avatar
    No, you can tell Samsung spent so much more time and effort into the dex.
    11-20-2017 11:01 PM
  10. dpham00's Avatar
    They still need to spend more time though... It is a good start but needs more work
    11-21-2017 04:04 PM
  11. Aljean Thein's Avatar
    Haven't used it. Dunno what's lacking tbh
    11-21-2017 04:57 PM
  12. dpham00's Avatar
    There are discussions and reviews of it if you are interested. I don't want to get into it here as this thread isn't about the dex
    11-22-2017 01:38 PM
  13. Aljean Thein's Avatar
    Sure. I'll look into it
    11-22-2017 04:23 PM
  14. Julienis's Avatar
    Hello,
    I come from France and I use since yesterday the Mate 10 Pro. It works great except the EMUI Desktop mode that I can not operate. I use this HDMI hub: https://www.youtube.com/redirect?eve...p%2FB07583JZLQbut when I connect my Mate 10 Pro to it, nothing happens on my HDMI screen, the screen is black and the smartphone does not detect that it must go into Desktop mode.
    Should you do a precise manipulation on the phone or use a specific HDMI hub?
    Thank you for your help because in France, no one finds the answer even HUAWEI.
    11-25-2017 07:24 AM
  15. tfp's Avatar
    Have you tried connecting directly to the monitor without using the hub?
    11-27-2017 11:40 AM
  16. tfp's Avatar
    Also, when i clicked the link, i got a warning about a vicious link/phishing link. Please don't click it.
    11-27-2017 11:41 AM
  17. Aljean Thein's Avatar
    Oh thanks for the info
    11-27-2017 05:40 PM
  18. dpham00's Avatar
    What did you think?
    11-29-2017 08:36 PM
  19. dpham00's Avatar
    Hello,
    Oh that sucks. Unfortunately I don't have a mate 10 but hopefully someone who does can help you
    11-29-2017 08:37 PM
  20. dpham00's Avatar
    Good point. Check to see if it works directly
    11-29-2017 08:37 PM
  21. dpham00's Avatar
    Oh that's no good! Thanks for the warning
    11-29-2017 08:38 PM
  22. dpham00's Avatar
    Most definitely. That could be a life saver
    11-29-2017 08:38 PM
  23. Aljean Thein's Avatar
    What did you think?
    Didnt look into it yet. Forgot about it
    11-29-2017 10:26 PM
  24. Aljean Thein's Avatar
    OP did you try this ?
    11-29-2017 10:26 PM
  25. Aljean Thein's Avatar
    Hello,
    Should try a different link
    11-29-2017 10:27 PM
108 ... 2345
  1. Turn off Sunlight Mode
    By BriniaSona in forum Samsung Galaxy Note 8
    Last Post: 10-21-2017, 09:02 AM
  2. My phone automatically switches off at sleep mode.
    Last Post: 10-21-2017, 02:54 AM
  3. How to change from Rad mode to normal mode in calculator for Nexus 5
    Last Post: 10-21-2017, 02:49 AM
  4. my HUawei Y550-L01 went into fastboot mode
    Last Post: 10-20-2017, 03:54 AM
  5. why I seeing my samsung note 3 in xray mode?
    Last Post: 10-19-2017, 10:25 PM
