04-10-2018 12:42 PM
100 123 ...
tools
  1. NeilMex's Avatar
    Does anybody know if the mate 10 comes with an always on display or ambient mode? I had a look online but couldn't find anything so I'm thinking no. When I went from the 6p to the mate 9 I really missed this feature and I'm trying to decide between the pixel 2xl and the mate 10.
    Thanks.
    10-21-2017 07:58 AM
  2. Djlarocca's Avatar
    I was having rouble finding answers on this as well. It certainly has the screen for it. Hopefully we'll find out sooner rather than later.
    10-21-2017 09:19 AM
  3. pjotrski's Avatar
    10-21-2017 02:25 PM
  4. dov1978's Avatar
    The Mate 9 Pro did so I'm HOPING the Mate 10 Pro also does. If it does it will be a done deal for me. That's the biggest thing stopping me completely committing to it right now. If it has double tap to wake as well then I'll be front of the queue on release day
    10-21-2017 03:31 PM
  5. Aljean Thein's Avatar
    Double tap to wake up is huge to me. let me know if they finaly implement this to their phones.
    11-03-2017 05:23 AM
  6. dpham00's Avatar
    I don't ever need to use such a feature on my note 8. Just long press on the aod to unlock the phone. Hopefully huawei can implement this
    11-03-2017 08:02 AM
  7. Aljean Thein's Avatar
    That works if they have aod. Haven't seen any reviewers talking about the aod tho
    11-03-2017 09:17 AM
  8. dpham00's Avatar
    Let's hope it does. It's a great feature
    11-03-2017 11:21 AM
  9. Aljean Thein's Avatar
    Yah im so used to it with my G6 now. Not sure how I'll feel without one.
    11-03-2017 04:20 PM
  10. dpham00's Avatar
    It will take some time but you could probably get used to not using it
    11-03-2017 05:24 PM
  11. Aljean Thein's Avatar
    I had my aod turned off to save some battery life couple of times before. But I didn't like it. I'd rather lose a tiny bit more battery life than turning aod off.
    11-03-2017 06:35 PM
  12. dpham00's Avatar
    How much does aod use on Huawei phones?
    11-03-2017 09:14 PM
  13. Aljean Thein's Avatar
    Never had the Mate 9 to test their aod. But I used a 3rd party and on my Honor 8 and the battery drain is noticeable on it. Can't remember how much it drains tho
    11-03-2017 09:42 PM
  14. inffy's Avatar
    I have a Mate 10 Pro review Sample from Huawei (got it from the launch event).
    First things first. This thing has a Always on Display mode in settings to activate (it isn't on by default). The bad news is that there isn't really any settings for it.
    Also it won't show any third party notifications on it. Only Huaweis few own apps.
    And no, there is no double tap to wake
    eljeffe58 likes this.
    11-04-2017 05:30 AM
  15. Aljean Thein's Avatar
    Limited aod and no double tap...sigh
    11-04-2017 08:06 AM
  16. dpham00's Avatar
    Third party aod is completely different and not optimized for the phone. On my note 8, the drain is pretty small, but aod was built in.
    11-04-2017 11:53 AM
  17. dpham00's Avatar
    Wow that sucks. That's like what Samsung did 2-3 years ago.
    11-04-2017 11:54 AM
  18. inffy's Avatar
    Yep. But this doesn't have final firmware. Although this has had four software updates already and no change. So I would guess that there won't be change atleast in the first official version
    11-04-2017 11:58 AM
  19. dpham00's Avatar
    Hopefully it can be added later via software update. I guess Huawei is experiencing whatever problem Samsung was having when they first launched aod. Glad to hear that they are actively working to update the software though. That's a good sign
    11-04-2017 12:31 PM
  20. Aljean Thein's Avatar
    Exactly but it works just fine. Only drain the battery lil more.
    11-04-2017 05:21 PM
  21. dpham00's Avatar
    Guess it depends on the person but I found the third party ones drained too much and wouldn't use them. But the oem ones were fine
    11-04-2017 06:37 PM
  22. Aljean Thein's Avatar
    Thanks inffy for providing details on the aod. Hopefully OP is satisfied.
    Also, I thought Mate 9 has aod ? OP did you not find that option in your Mate 9 settings?
    11-05-2017 09:12 AM
  23. dpham00's Avatar
    I don't think it had it originally.
    11-05-2017 02:47 PM
  24. Aljean Thein's Avatar
    Oh, they added it in a update?
    11-05-2017 10:34 PM
  25. dpham00's Avatar
    Mate 9 didn't have aod originally. Not sure if it was added yet
    11-06-2017 12:43 AM
100 123 ...
  1. why Ads come on my device
    Last Post: 10-21-2017, 02:17 PM
  2. Replies: 1
    Last Post: 10-21-2017, 02:15 PM
  3. Replies: 0
    Last Post: 10-21-2017, 07:37 AM
  4. Pixel 2 XL Contact Widget blue icon on Photo
    Last Post: 10-21-2017, 07:25 AM
  5. How to crop a photo on Samsung 8s
    Last Post: 10-21-2017, 06:15 AM
