11-10-2017 01:25 AM
29 12
tools
  1. PiotrJot's Avatar
    Hello,
    I am wondering if anyone installed the BlackBerry Hub application on it. If so, does it work well? Does it refresh the emails in the background?
    I am asking, as somehow it doesn't work with Huawei MediaPad.
    Thanks for all the replies 👍
    10-31-2017 01:47 PM
  2. jasonandrews25788's Avatar
    I tried it once and it worked flawlessly
    10-31-2017 03:49 PM
  3. Aljean Thein's Avatar
    Don't see why it wouldn't work. Worked fine with my other Huawei phones. 5X and Honor 8
    11-02-2017 02:21 PM
  4. dpham00's Avatar
    It works fine on my honor 8 too.
    11-02-2017 04:43 PM
  5. Aljean Thein's Avatar
    if youre asking cause of the 18:9 ratio..works fine on my G6
    11-02-2017 08:23 PM
  6. dpham00's Avatar
    Works fine on my note 8 too
    11-02-2017 09:02 PM
  7. PiotrJot's Avatar
    Thanks for all the replies.
    I did not mean the aspect ratio.
    I installed the Hub on some Samsung phones, and it worked fine. Recently I installed it on my son's tablet, Huawei MediaPad 3. It simply doesn't work in the background. Once you open the Hub, the emails flow, but when the app is minimized, it refuses to keep working.
    Anyway, I am glad it works on the phone, since I am considering it as my next phone, among few others.
    11-04-2017 02:32 PM
  8. dpham00's Avatar
    Interesting. I can check it out on my m3 when I get a chance.
    11-04-2017 03:58 PM
  9. Aljean Thein's Avatar
    Let me know if your M3 works fine. I can check on mine as well
    11-04-2017 07:44 PM
  10. dpham00's Avatar
    Oh if you can check then that would be great. I was going to look but apparently I misplaced it somewhere
    11-05-2017 01:51 AM
  11. Aljean Thein's Avatar
    Sure. I'll check when I get home after work
    11-05-2017 05:24 AM
  12. dpham00's Avatar
    That would be great. I will try to keep looking for mine if I have time
    11-05-2017 11:19 AM
  13. Aljean Thein's Avatar
    Some for reason I can't find the BlackBerry Hub app in my M3 app store. OP did you download an apk app for it ?
    11-05-2017 04:30 PM
  14. PiotrJot's Avatar
    That is strange.
    No, I installed it from here Play Store.
    I'm now away in a business trip, and the M3 was left at home, so I am not sure if the below given links were the same I found from the tablet, but my Samsung phone shows me following apps from the Play Store:
    BlackBerry services first https://play.google.com/store/apps/d...infrastructure
    And the Hub https://play.google.com/store/apps/d...blackberry.hub
    Thanks again for looking into this!
    11-05-2017 04:38 PM
  15. Aljean Thein's Avatar
    Apparently my device isn't compatible for that app. Weird. I'll try the apk version and get back to you.
    11-05-2017 04:41 PM
  16. dpham00's Avatar
    That's weird that it isn't compatible with the m3? Wonder why that is
    11-05-2017 04:58 PM
  17. Aljean Thein's Avatar
    I downloaded the apk version for the Hub and the Hub+ Subscription app. so far my emails are populating in the background. I'll see how it is later in the day
    11-05-2017 05:07 PM
  18. dpham00's Avatar
    Glad to see it's working for now!
    11-05-2017 06:24 PM
  19. Aljean Thein's Avatar
    Not sure how OP is not getting them.
    11-05-2017 07:51 PM
  20. dpham00's Avatar
    Maybe it needs to be white listed to run in the background?
    11-06-2017 12:30 AM
  21. Aljean Thein's Avatar
    Maybe.
    I didn't do anything in the settings to get it working.
    Gotta wait for OP to get back from his business trips and check it out
    11-06-2017 01:31 AM
  22. PiotrJot's Avatar
    Thanks for all the feedback! I should have the access to the M3 when get back home, around the end of the week.
    I will post the result for sure!
    11-06-2017 06:23 AM
  23. dpham00's Avatar
    Maybe.
    Ok. Well there's always the fdr option though that's a last resort. It has worked for me in the past fixing an app that wasn't working though.
    11-06-2017 07:44 AM
  24. Aljean Thein's Avatar
    If factory reset works then OP should try it. Of course back up your data first.
    11-06-2017 08:04 AM
  25. Aljean Thein's Avatar
    So far everything is working just fine. If you want, you can download the apk version to get it working like I did
    11-08-2017 02:41 AM
29 12
  1. Teclast T10 - Flip Cover: Screen On/Off Control
    Last Post: 04-24-2018, 08:32 AM
  2. Wifi connection problems on Samsung Galaxy A3 2017
    Last Post: 11-04-2017, 06:32 PM
  3. My zte majesty pro won't let me send or receive pictures or videos
    Last Post: 10-31-2017, 03:54 PM
  4. Ads on home screen
    Last Post: 10-31-2017, 03:51 PM
  5. CSC change on Samsung A5 SM-A520F
    Last Post: 10-31-2017, 12:00 PM
