12-27-2017 03:42 AM
98 123 ...
tools
  1. Hanlon10's Avatar
    Here's a few thoughts from my first 2 days of usage:
    - The fingerprint scanner is lightening fast and it hasn't failed to authenticate once yet.
    - Battery life appears to be above average but not amazing like everyone was expecting from a 4000mAh battery, though it does charge exceptionally quickly.
    - As expected from EMUI, there's a tonne of bloatware.
    - Annoyingly, there's no double-tap screen on, or that setting the 6P had where you point the screen at your face and it recognises you're looking at it so turns on (can't remember the name for it, and I'm not talking about face unlocking like iris scan etc), so literally the only way to wake your screen is to press the power button (or unlock with fingerprint scanner). Not very convenient though if you just want to quickly check the time and the phone is on a flat surface.
    - As a result of the above, I have turned on AOD. This is tucked away in settings and you have to search for it (as far as I'm aware)
    - Notifications are a bit of a conundrum, they disappear when you unlock the phone and then lock it again despite not reading them. I'd still expect some form of notification to display to remind me I still have unread notifications.
    - The notification light is very small and often difficult notice when it's flashing.
    - Call and notification volume are linked so you cannot alter these 2 separately without the use of a third party app.
    - My biggest qualm at the minute is trying to swipe down. This could just be me and it will no doubt improve over time but I am often finding that when I swipe down, unless I'm really concentrating to make a perfect vertical swipe, it often mistakes it for a side swipe. Furthermore, when trying to swipe down to view your notifications, unless you are literally swiping down from the top of the screen, it mistakes this swipe for another which takes you into a search for settings screen, this is extremely frustrating.
    I does sound like I'm really hammering the phone to be fair but these are all minor issues and could be completely irrelevant for other users, I had a few teething problems on my Nexus 6P when I first got that and grew to love it. Apart from the above points it really does seem to be a great phone, hopefully some of the points I've been mentioned could be ironed out in a software update as well.
    Anyway, sorry for rambling on...just wanted to hear thoughts from anyone else who has the phone and see if they're experiencing any of the same issues?
    Cheers
    Guytronic likes this.
    11-20-2017 11:17 AM
  2. FutureMech's Avatar
    Mate 9 has the best battery life, now the mate 10 is the king, according to AC, and i believe its true.
    though mate 10 had some software issue that drained battery quickly, have you got any updates?
    Check your battery usage and post it here if possible
    11-20-2017 04:32 PM
  3. dpham00's Avatar
    Cheers
    The notification disappearing thing is apparently common across multiple Huawei phones. It's just the way they do things unfortunately.
    11-20-2017 06:24 PM
  4. dpham00's Avatar
    It's even better than the s8 active?
    11-20-2017 06:25 PM
  5. Hanlon10's Avatar
    2 screens attached, let me know what you make of them :-D
    Attached Thumbnails Mate 10 Pro initial thoughts-screenshot_20171121-084703.jpg   Mate 10 Pro initial thoughts-screenshot_20171121-084646.jpg
    11-21-2017 03:51 AM
  6. Hanlon10's Avatar
    Ah well that's a shame, nevermind!
    11-21-2017 03:53 AM
  7. Aljean Thein's Avatar
    Cheers
    Unfortunately Huawei didn't add the double tap to wake up. Have you noticed any big battery drained from using aod and without it?
    The notifications problem is indeed a Huawei thing. Not sure why they did that. Maybe with enough complaint they'll fix it
    11-21-2017 05:16 AM
  8. Aljean Thein's Avatar
    Looks like you're been using it for over a day without charging it. You don't think this is impressive?
    11-21-2017 05:17 AM
  9. Hanlon10's Avatar
    AOD hardly had any effect on battery life, well worth having it on IMO
    11-21-2017 06:27 AM
  10. Hanlon10's Avatar
    I used to get similar results with my N6P when I first got that so I'm not exactly blown away. Plus I hadn't exactly been streaming videos all day, just general web browsing with my screen brightness around 40%.
    As long as it last me a day I'm happy anyway. I'm just not sure about these claims of having phenomenal battery life.
    11-21-2017 06:33 AM
  11. FutureMech's Avatar
    Never tested against but it might be
    11-21-2017 07:28 AM
  12. FutureMech's Avatar
    Your screenshots looks ok to me, give it couple of days to adjust and then judge it i guess
    11-21-2017 07:29 AM
  13. Aljean Thein's Avatar
    Nice. That's great to hear
    11-21-2017 07:31 AM
  14. FutureMech's Avatar
    I attached mine states, so you can compare, this is from oreo Beta 321
    Attached Thumbnails Mate 10 Pro initial thoughts-screenshot_20171121-143115.jpg   Mate 10 Pro initial thoughts-screenshot_20171121-143108.jpg   Mate 10 Pro initial thoughts-screenshot_20171121-143101.jpg
    11-21-2017 07:32 AM
  15. Aljean Thein's Avatar
    As long as you're satisfied with a full day usage then it's good. Battery life are different with everyone depending on their usage
    11-21-2017 07:33 AM
  16. Aljean Thein's Avatar
    This looks about right. You're 4hrs in and got nearly 70% left. I think the reviews were stating they got 8-10hrs sot with it depending on usage
    11-21-2017 07:35 AM
  17. FutureMech's Avatar
    i expect the 10 pro to beat the 9, and the normal 10 probably be in between.
    11-21-2017 07:42 AM
  18. br77494's Avatar
    Wow!
    11-21-2017 01:53 PM
  19. priceslss's Avatar
    I am trying to wait a few days before I scream my battery life is worse than my Mate 9 and my Mate 9 pro were... For now I am not seeing the same battery life that I got out of either of those devices but I have not had the device a week yet.
    recDNA likes this.
    11-21-2017 02:36 PM
  20. FutureMech's Avatar
    Those are my stats, closing the day with that soon.
    Never saw phone as good as the Mate 9, probably the Mate 10 pro gonna top it easily
    Attached Thumbnails Mate 10 Pro initial thoughts-screenshot_20171121-205206.jpg   Mate 10 Pro initial thoughts-screenshot_20171121-205212.jpg   Mate 10 Pro initial thoughts-screenshot_20171121-205157.jpg
    11-21-2017 03:17 PM
  21. Aljean Thein's Avatar
    What kind of battery life are you getting ?
    11-21-2017 03:45 PM
  22. Aljean Thein's Avatar
    Great battery life !
    11-21-2017 03:45 PM
  23. FutureMech's Avatar
    Ty , i hope battery life will get better for him, as i'm eyeing the Pro too .
    But, tbh the Mate 9 is just so good, nothing is tempting at all, even the DAC is decent, just wish they had a great dac like in V30, so it could power up mine ATH E70 and all other equipment.
    11-21-2017 04:35 PM
  24. dpham00's Avatar
    What sot are you getting?
    11-21-2017 04:44 PM
  25. dpham00's Avatar
    It really shouldn't drain much given that it's a manufacturer solution
    11-21-2017 04:45 PM
98 123 ...
  1. Replies: 34
    Last Post: 11-22-2017, 06:00 PM
  2. HTC 10 video showing blank
    By Android Central Question in forum HTC 10
    Last Post: 11-20-2017, 12:20 PM
  3. How do I root a Samsung galaxy j7 sky pro
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 11-19-2017, 01:57 PM
  4. HTC 10 video showing blank
    Last Post: 11-19-2017, 03:42 AM
  5. How do I root a Samsung galaxy j7 sky pro
    Last Post: 11-18-2017, 10:48 PM
