1. hoyam's Avatar
    How to enable finger print app lock without enabling screen lock. I have mate 10 pro and screen lock prevents voice commands unless unlocked and it's a big issue for me while driving.
    I tried every setting and even downloaded CM app lock but same problem.
    I don't understand why fingerprint have to be linked to screen lock 🤦*♀️
    01-30-2018 02:33 PM
  2. SpookDroid's Avatar
    It's linked because then what's the point of the fingerprint? It becomes just a button. The FP reader is only active if you have a secure screen lock or for secure transactions/unlocks within apps.
    You can use Android Auto and it will accept voice commands while driving.
    01-30-2018 02:43 PM
  3. brutos08's Avatar
    I don't think that is possible at All
    01-30-2018 06:44 PM
  4. hoyam's Avatar
    Oh that's a bummer
    How to activate android auto? For instance if I want to make a call or send a text message
    01-31-2018 02:09 PM
  5. SpookDroid's Avatar
    Oh that's a bummer
    There are a few ways to do this.
    1) If your audio system supports it. Most cars with phone functions can let you text and call using voice with their built-in system. The 'how', however, depends on your system, but usually pressing the command button and saying 'Message CONTACT' or something like that works.
    2) If your phone supports audio commands while driving. Some devices have a 'Driving Mode' that helps with this, but it needs to be activated from the settings. Not all devices have it, however.
    3) Android Auto. Just download the app from the Play Store, install, and either open it manually or have it run automagically when you're in your car. It'll show a simplified screen for quick shortcuts but will also work with voice commands while driving as if you were using Google's Assistant.
    hoyam likes this.
    01-31-2018 05:04 PM
  6. NYVET's Avatar
    Don't know if this will solve your issue, but I just found a third party screen lock app that let's me use fingerprint unlock WITHOUT entering a PIN. I have a PIN set as a backup, but all I do now is touch the fingerprint scanner and my phone unlocks no matter what method I use to lock (turn off) the screen. I hated how the only way was to lock with the power button (or natural time out settings, not very convenient obviously), and if I went to wake up my device using the proximity sensor, it would force me to use my PIN. Turns out this is not a Samsung issue, it's a DEVELOPER issue, in that they failed to incorporate this unlock method into their apps. But I found an app that will work, called 'Hi Locker'. Free with a paid pro version ($1.99). Highly customizable and lots of features, or you an just use what you need to use. Hope this helped.
    02-14-2018 07:30 PM
  7. amyf27's Avatar
    I don't have the Mate 10, but it should have an option where you can max out the time before the phone actually locks the screen, like 30 minutes. That way you'll probably be using it regularly and it may just screen time out but not lock. That's what I usually do
    02-14-2018 07:41 PM
  8. laWiskaPY's Avatar
    Sorry for being years late, maybe it will help someone else.
    this is useful for apps that have applock, they will use the fingerprint to unlock, magisk will ask for fingerprint to accept requests, but the phone will not be locked.
    It's a long process
    requires a custom recovery and reinstall the rom.
    activate the non-encryption patch after installing the rom
    add password and fingerprint
    then reboot to recovery, system, cut the file "lockscreen" or similar to a location to restore in case it doesn't work.
    If the patch is not applied and the phone is encrypted, it will remain in "initial android" the password is the encryption key.
    07-26-2022 07:54 PM
  1. How to stop app stores shortcuts from making new screens
    Last Post: 02-11-2018, 12:32 PM
  2. my hyf e1 not installing app
    Last Post: 01-30-2018, 09:34 PM
  3. Why can't I find half. My phone numbers when I type a name on the keypad screen?
    Last Post: 01-30-2018, 12:31 PM
  4. App with G logo
    Last Post: 01-30-2018, 12:26 PM
  5. Where has my text messaging app gone.
    Last Post: 01-30-2018, 12:24 PM
