1. N1cks's Avatar
    I saw an article on CNET on wireless charging receivers.
    Yeah, I know the Mate 10 Pro has rapid charging, but if I were to get a wireless charging receiver... would it be safe to use with the Mate 10 Pro.
    The Mate 10 Pro charger is 4.5 V/5 A.
    The wireless receiver has an output of 5V/1A (Max).
    I was never good at high school physics - is the wireless receiver okay for the Mate Pro 10?
    01-30-2018 11:18 PM
  2. Rukbat's Avatar
    Yes.
    The phone draws as much as it's designed to draw - up to the limit that the charger can supply. The wireless charger won't charge the phone as quickly as the plug-in charger, but it's safe to use with a wireless charging pad (which you have to buy separately), and the wireless receiver is safe to use with the phone.
    N1cks likes this.
    01-31-2018 01:00 PM
  1. Charging issues with Samsung Note 4
    By Waffenmarx in forum Ask a Question
    Last Post: 01-31-2018, 01:02 PM
  2. my galaxy j7 sky pro will not down load any thing
    Last Post: 01-30-2018, 08:54 PM
