01-19-2019 05:50 PM
208 ... 789
tools
  1. brutos08's Avatar
    Got it yesterday decided to check as I don't use my mate anymore and saw the update.
    01-11-2019 05:40 AM
  2. dov1978's Avatar
    After the long wait for 9.0 Pie I think that update was a curse. Had my Mate 10 Pro for almost a full year now and it's been in great condition throughout in its Spigen Rugged Armor case. I was trying out the new gestures and found they worked a lot better without the case when swiping in from the sides to go back. Maybe shouldn't have done that eh? It only slid down my car dashboard toward the windscreen and didn't even fall or hit anything. Glad I'm due an upgrade next month now lol
    01-11-2019 04:54 PM
  3. turbogo's Avatar
    Updated Huawei Mate 10 Pro UK from EMUI 8 to EMUI 9 with Android Pie, and Eye comfort is now useless. There is virtually no difference between off & on max settings, it worked perfectly on EMUI 8. Not sure if this is a Huawei or Android Pie problem. I have very light sensitive eyes so this problem is really affecting me.
    If you have light sensitive eye I would not update software.
    01-15-2019 07:11 AM
  4. tomdurkin's Avatar
    Ouch that doesn't look good.
    Finally rolled out to my device this morning. Not the biggest changes but seems to be running fast. And to hand it to Huawei, they did beat Samsung for their UK S9/N9.
    01-15-2019 07:32 AM
  5. tomdurkin's Avatar
    Search for Twilight on the Play Store for a better and more customisable blue light filter
    01-15-2019 07:33 AM
  6. turbogo's Avatar
    Hey Thanks i have had to use Twilight, but these are screen overlays so no longer work on the pull down menu, before Huawei update the Eye comfort work perfectly well.
    01-15-2019 10:04 AM
  7. garethrdwilliams's Avatar
    bizarre that eye comfort for me still works as it should.
    01-19-2019 12:05 PM
  8. dov1978's Avatar
    And same for me. Just 5 or 6 other bugs that annoy me instead
    01-19-2019 05:50 PM
208 ... 789
  1. Anyone know when another Tizen update is going to happen?
    By terobaje in forum Samsung Gear S3
    Last Post: 05-27-2018, 09:54 PM
  2. Gear S2 Update
    By WVTip in forum Samsung Gear S2
    Last Post: 03-31-2018, 11:40 AM
  3. Why are my contact notifications gone after latest update?
    Last Post: 03-27-2018, 02:04 PM
  4. Huawei p10, front camera settings?
    By Android Central Question in forum Huawei P10 & P10 Plus
    Last Post: 03-27-2018, 12:36 PM
  5. Huawei p10, front camera settings?
    Last Post: 03-27-2018, 11:57 AM
