1. NightOrchid's Avatar
    Hey folks
    I had to return my C782 M10P due to a speaker issue, however, my new Mate10P is now a C432.
    The OS build is 8.0.0.125(C432) but the security OS is 6th Nov 2017, which seems really old, and theres no new updates..
    Are any other Vodafone UK users running anything different
    EDIT...
    OK after much reading around.. Ive found out it should be C782 which is UK.. C432 is EU.. Whoever had the phone before me.. has tried to de-brand it and flashed the Wrong firmware..
    Thanks
    05-01-2018 02:43 PM
  2. brutos08's Avatar
    Hey folks
    EDIT...
    Thanks
    Vodafone UK is C432 and unlocked versions from CPW is C782 like mine.
    05-02-2018 09:31 AM
  1. How can I use my Nexus 6 today?
    By Mahesh Abnave in forum Google Nexus 6
    Last Post: 08-13-2018, 02:35 PM
  2. Using Helium Backup (Premium) to back up to my SD Card (no USB port)
    Last Post: 05-01-2018, 12:37 PM
  3. Is there another way to select an option, other than using the power button?
    Last Post: 05-01-2018, 10:23 AM
  4. Why do some images not appear using Samsung Internet?
    Last Post: 05-01-2018, 10:17 AM
  5. Does anyone know a IOS look a like rom
    By Android Central Question in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 05-01-2018, 05:07 AM
